| NC_Colfax |
Sep 2 2010, 04:31 PM
Member ![]() ![]() Group: Members Posts: 130 Joined: 26-July 10 From: North Carolina Member No.: 11,982 Region Association: South East States |
Looking for a used set of headers to replace the heat exchangers. 1 1/2 perfered but 1 5/8 would also work.
I am going to be working on the valve cover and adjusting the valves soon.I would like to replace the exhaust at the same time. Thanks in Advance (IMG:style_emoticons/default/piratenanner.gif) |
| rwilner |
Sep 2 2010, 04:40 PM
No Ghosts in the Machine ![]() ![]() ![]() Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
Looking for a used set of headers to replace the heat exchangers. 1 1/2 perfered but 1 5/8 would also work. I am going to be working on the valve cover and adjusting the valves soon.I would like to replace the exhaust at the same time. Thanks in Advance (IMG:style_emoticons/default/piratenanner.gif) This is SOT, but just a few notes for you -- I apologize if you know all this stuff already, but it sure would have helped me when i swapped my exhaust. - When you replace the exhaust, make sure you get a set of the special copper gaskets, and make sure you take the old ones out. A dental pick will help. And be careful -- sometimes people put new ones on without taking the old ones out, so you may have layers of old copper gaskets in there. - If you're getting headers you may need the stubs too, so make sure they're included or budget for a set of those. - If you have the cash, Chris Foley's header is supposed to be da shizz. - Be very careful not to overtighten the nuts on the exhaust studs. the studs are steel and the block is aluminum so you could easily strip out the threads in the head, which means it's helicoil time. |
| underthetire |
Sep 2 2010, 04:43 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Looking for a used set of headers to replace the heat exchangers. 1 1/2 perfered but 1 5/8 would also work. I am going to be working on the valve cover and adjusting the valves soon.I would like to replace the exhaust at the same time. Thanks in Advance (IMG:style_emoticons/default/piratenanner.gif) There are OBX headers on evilbay, not sure about them, never used them myself. The tangerine headers are awesome but may be out of your budget? |
| NC_Colfax |
Sep 2 2010, 04:44 PM
Looking for a used set of headers to replace the heat exchangers. 1 1/2 perfered but 1 5/8 would also work. I am going to be working on the valve cover and adjusting the valves soon.I would like to replace the exhaust at the same time. Thanks in Advance (IMG:style_emoticons/default/piratenanner.gif) This is SOT, but just a few notes for you -- I apologize if you know all this stuff already, but it sure would have helped me when i swapped my exhaust. - When you replace the exhaust, make sure you get a set of the special copper gaskets, and make sure you take the old ones out. A dental pick will help. And be careful -- sometimes people put new ones on without taking the old ones out, so you may have layers of old copper gaskets in there. - If you're getting headers you may need the stubs too, so make sure they're included or budget for a set of those. - If you have the cash, Chris Foley's header is supposed to be da shizz. - Be very careful not to overtighten the nuts on the exhaust studs. the studs are steel and the block is aluminum so you could easily strip out the threads in the head, which means it's helicoil time. Yes thanks but really not looking to spend that kind of $$. They are super nice. I am just hoping for a decent used set off a race car or parted out car. |
| NC_Colfax |
Sep 2 2010, 04:47 PM
Yeah I saw the OBX....just not sure about them either. I like the price but I know some of their turbo headers were junkie looking. Saw a few years ago at a car show and all had leaks on the the pipe side of the flange.
| EdwardBlume |
Sep 3 2010, 08:20 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,340 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California
I have a set... the ad might still be around somewhere..
| NC_Colfax |
Sep 3 2010, 01:14 PM
| dlwbbr |
Sep 12 2010, 07:51 AM
I'm new here ... Group: Members Posts: 0 Joined: 29-August 10 From: Atlanta -30041 Member No.: 12,118 Region Association: South East States |
Looking for a used set of headers to replace the heat exchangers. 1 1/2 perfered but 1 5/8 would also work. I am going to be working on the valve cover and adjusting the valves soon.I would like to replace the exhaust at the same time. Thanks in Advance (IMG:style_emoticons/default/piratenanner.gif) See attached FS. parts list-includes new header and Supertrapp. Thanks, Dan W. dlwbbr@yahoo.com |
| dlwbbr |
Sep 13 2010, 08:21 AM
Looking for a used set of headers to replace the heat exchangers. 1 1/2 perfered but 1 5/8 would also work. I am going to be working on the valve cover and adjusting the valves soon.I would like to replace the exhaust at the same time. Thanks in Advance (IMG:style_emoticons/default/piratenanner.gif) This is SOT, but just a few notes for you -- I apologize if you know all this stuff already, but it sure would have helped me when i swapped my exhaust. - When you replace the exhaust, make sure you get a set of the special copper gaskets, and make sure you take the old ones out. A dental pick will help. And be careful -- sometimes people put new ones on without taking the old ones out, so you may have layers of old copper gaskets in there. - If you're getting headers you may need the stubs too, so make sure they're included or budget for a set of those. - If you have the cash, Chris Foley's header is supposed to be da shizz. - Be very careful not to overtighten the nuts on the exhaust studs. the studs are steel and the block is aluminum so you could easily strip out the threads in the head, which means it's helicoil time. I have a new Chris Foley ceramic coated header for 914 $1,100. Thanks, Dan Williams dlwbbr@yahoo.com |
| NC_Colfax |
Sep 13 2010, 04:31 PM
I have purchased a set
Thanks |
Lo-Fi Version | Time is now: 9th June 2026 - 02:09 AM |
