| Gigamight |
Sep 3 2010, 11:52 AM
Member ![]() ![]() Group: Members Posts: 220 Joined: 8-June 09 From: Near Akron, Ohio Member No.: 10,454 Region Association: Middle East |
| type47 |
Sep 4 2010, 01:23 PM
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
You should be able to test the resistance to tell if it's good, it's just a thermal resistor.
| Gigamight |
Sep 4 2010, 06:12 PM
| type47 |
Sep 6 2010, 08:13 AM
Take a Volt-Ohm meter (VOM) and set the selector to measure ohms. Take the 2 leads and touch one lead to the body of the sensor and the other to the male spade terminal. Easier to just see pix than write explanation. (IMG:style_emoticons/default/biggrin.gif)
| Gigamight |
Sep 6 2010, 10:36 AM
Take a Volt-Ohm meter (VOM) and set the selector to measure ohms. Take the 2 leads and touch one lead to the body of the sensor and the other to the male spade terminal. Easier to just see pix than write explanation. (IMG:style_emoticons/default/biggrin.gif) ![]() ![]() Fantastic! Thank you. I will be digging out my multi. (I have one, just never learned how to use it) |
| c12croft |
Sep 6 2010, 11:18 AM
Member ![]() ![]() Group: Members Posts: 167 Joined: 24-December 04 From: Long Island, New York Member No.: 3,331 |
Take a Volt-Ohm meter (VOM) and set the selector to measure ohms. Take the 2 leads and touch one lead to the body of the sensor and the other to the male spade terminal. Easier to just see pix than write explanation. (IMG:style_emoticons/default/biggrin.gif) Fantastic! Thank you. I will be digging out my multi. (I have one, just never learned how to use it) As a thermister there should be chart to verify temp v. resistance? |
| type47 |
Sep 9 2010, 09:43 AM
Lo-Fi Version | Time is now: 9th June 2026 - 02:09 AM |
