are dashs the same for all years |
crxnug |
Sep 4 2010, 07:40 PM
Member Group: Members Posts: 81 Joined: 20-December 07 From: ontario, canada Member No.: 8,489 |
are there any differences in dashs the the years, if so does someone have a pic or info on how to tell the differences,
bdstone914 |
Sep 4 2010, 07:54 PM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Lennies914 |
Sep 4 2010, 07:55 PM
Slacker Group: Members Posts: 828 Joined: 9-January 10 From: NorCal Member No.: 11,216 Region Association: Northern California |
The early dashes will fit all years, but the later dashes will not fit the early cars ('70-'71 I think). When they added the vents in the glove box door was made smaller. Therefore the notch on the underside of the dash is not long enough on the later models to accomidate the larger glove box door on the early cars. I hope that made sense.
jt914-6 |
Sep 4 2010, 08:00 PM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
The '70-71 dashes had three defrost vents on the four cyl. cars. The sixes had two. In '72 side vents were added and lost the center deftost vent.
Dr Evil |
Sep 4 2010, 09:31 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
The "dashes" are all the same if you are only referring to the top cap. The vents change the lower dash or the vinyl piece that covered the area between the dash cap and the windshield (IMG:style_emoticons/default/wink.gif)
realred914 |
Sep 4 2010, 09:40 PM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
The "dashes" are all the same if you are only referring to the top cap. The vents change the lower dash or the vinyl piece that covered the area between the dash cap and the windshield (IMG:style_emoticons/default/wink.gif) no, the dash top was different also when the side vents appeard, minor side detail, if you put a late dash on an early cars lower dash assemble, you cant open the early bigger glove box door all the way, it will hit the later dash top. in dash top i refer to the big foam/vinyl piece that forms the hood over the instruments and runs the width of the car. this can be an issue when foks replace cracked dash tops, you need to be specifc about the style not all folks are even aware of the difference. just been thru this issue with a friends 914, so that how I learned yes early cars had an extra windshield vent. in the middle , however it was not mounted on the foam/vinyl dash top, but rather on the metal dash structure that is forward of the dash top. hope that makes sense |
Lo-Fi Version | Time is now: 9th June 2024 - 03:56 PM |
