Fibreglass panels, Who makes the best quality? |
phillstek |
Sep 10 2010, 04:14 PM
Member Group: Members Posts: 350 Joined: 19-May 10 From: Byron Bay, Australia Member No.: 11,741 Region Association: None |
My car is at the painter getting a full bare metal respray and I want to replace the bonnet and boot lids with grp ones. Any suggestions for which ones to go for?
I want to use the original latches as opposed to pins. Thanks, Phil |
dr914@autoatlanta.com |
Sep 10 2010, 05:02 PM
914 Guru Group: Members Posts: 7,885 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
metal metal or metal. Fiberglass is only for racing where one wants to suffer for the sake of light weight
My car is at the painter getting a full bare metal respray and I want to replace the bonnet and boot lids with grp ones. Any suggestions for which ones to go for? I want to use the original latches as opposed to pins. Thanks, Phil |
Tom_T |
Sep 10 2010, 07:08 PM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
I want to use the original latches as opposed to pins. IIRC there are none on which you can use the latches & springs, & I'd think the spring pressures would tear them up. All factory or M471 type racers had pins at front & straps at rear only - due to the relative flimsiness of the FG/GRP/etc. racing lids. I'd follow George's advice & stick with the steel lids, which I've seen some folks drill holes in the underside frames to reduce weight, but that too may induce rust. |
campbellcj |
Sep 11 2010, 11:18 PM
I can't Re Member Group: Members Posts: 4,547 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
The Getty lids are very nice quality and can use the stock hinges and latches; however, I agree they may not like the stock-strength springs. On mine I've ditched the latches and springs and I use pins/straps, but the mount points for the latches are there.
Mike Bellis |
Sep 11 2010, 11:56 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I had an A.I.R. rear lid with duck tail. It uses the original latch and hinges. It is heavy duty and weighs almost as much as the steel lid.
carr914 |
Sep 12 2010, 12:33 AM
Racer from Birth Group: Members Posts: 118,899 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
Getty Designs
sean_v8_914 |
Sep 12 2010, 03:23 AM
Chingon 601 Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 |
Jeff at QRS in Hemet CA. he sells on ebay. he can make a lid to suit your needs...thin for racing or hticker for street rigidity and a nicer paint finish
Lo-Fi Version | Time is now: 31st May 2024 - 11:34 PM |
