Vent On Oil Filler, Blowing air into the atmosphere |
7TPorsh |
Sep 20 2010, 12:05 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
There is a fitting on the little box where the oil filler is. i have a dual carb setup. i am guessing this is the vent for the crankcase. It blows pretty good when the engine is running.
I guess on a stock car this routes to the air filter setup; where should it go on a dual carb? Air cleaners don't have any place. |
tradisrad |
Sep 20 2010, 12:11 PM
Senior Member Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
It needs to goto the air cleaner. Can you put a tube into the air cleaner to attach the hosme to?
7TPorsh |
Sep 20 2010, 12:22 PM
No holes on the air cleaner holders. I have velocity stacks inside the oval shaped cleaners. no fittings on the cleaners top or bottom.
i suppose I need to drill a hole and put a grommet? Fitting? I imagine there must be something out there. lots of us have the carbs; is there no easy solution? Maybe I need new cleaners? but I'm a CSOB... |
70_914 |
Sep 20 2010, 07:52 PM
Member Group: Members Posts: 395 Joined: 4-December 09 From: Roy, WA Member No.: 11,096 Region Association: Pacific Northwest |
No holes on the air cleaner holders. I have velocity stacks inside the oval shaped cleaners. no fittings on the cleaners top or bottom. i suppose I need to drill a hole and put a grommet? Fitting? I imagine there must be something out there. lots of us have the carbs; is there no easy solution? Maybe I need new cleaners? but I'm a CSOB... You can run a breather box setup. Usually consists of one hose from each valve cover and one from that filler "box". K&N makes one specific for small displacement, high performance VW motors that includes some baffles in order to keep oil from escaping. Empi has a box with a sponge inside, works in a similar fashion. Venting to the atmosphere will not work as well as running a hose to your air cleaner base, though. Pressure will build up inside your case on long uphill runs if you vent to the atmosphere. Best system is to use scavengers welded to your exhaust that will pull a vacuum in your engine, but there are opinions that a flat 4 does not make the even exhaust pulses needed to pull pressure from the case. (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 3rd June 2024 - 05:47 AM |
