QUOTE(7TPorsh @ Sep 20 2010, 11:22 AM)
No holes on the air cleaner holders. I have velocity stacks inside the oval shaped cleaners. no fittings on the cleaners top or bottom.
i suppose I need to drill a hole and put a grommet? Fitting? I imagine there must be something out there.
lots of us have the carbs; is there no easy solution? Maybe I need new cleaners?
but I'm a CSOB...
You can run a breather box setup. Usually consists of one hose from each valve cover and one from that filler "box". K&N makes one specific for small displacement, high performance VW motors that includes some baffles in order to keep oil from escaping. Empi has a box with a sponge inside, works in a similar fashion.
Venting to the atmosphere will not work as well as running a hose to your air cleaner base, though. Pressure will build up inside your case on long uphill runs if you vent to the atmosphere. Best system is to use scavengers welded to your exhaust that will pull a vacuum in your engine, but there are opinions that a flat 4 does not make the even exhaust pulses needed to pull pressure from the case.
