Loose front trunk hinges. Is this Normal? |
yrret7 |
Sep 26 2010, 11:11 PM
Newbie Group: Members Posts: 18 Joined: 21-September 10 From: Kingston Ont, Canada Member No.: 12,202 Region Association: Canada |
I removed my front trunk lid to line up the hood better and found that the hinges are very loose. Once the tension of the spring was removed it was even worse. Is this normal? I thought perhaps the bolt was loose but this was not the case. I'm not sure if the hole has increased in size or if the shouldered bolt is worn smaller. Would a washer help ? Anyone had this issue before?
Thanks!! |
Cupomeat |
Sep 26 2010, 11:56 PM
missing my NY 914 in VA Group: Members Posts: 1,336 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
Ok, I've never relieved the spring pressure on my front hood, but the hinges do not appear to allow too much lateral play before flexing the metal. I hope that helps. |
Andyrew |
Sep 27 2010, 01:15 AM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Can you get a bolt on it tight?Put a couple of washers on the bolt and see if you can tighten it down. If not, then something is fishy in the hood nut. Post some pics!
TheCabinetmaker |
Sep 27 2010, 06:12 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Its been a while, but, I think there is a plastic bushing that the bolt goes thru.
Bartlett 914 |
Sep 27 2010, 07:44 AM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Its been a while, but, I think there is a plastic bushing that the bolt goes thru. Steel bolt in a steel hole. Often freezes up from rust. This is a place where there should be a place to lubricate. The bolt head doesn't allow easy lubricating. The hinges are a little loose on the cars I have seen. Better loose than frozen. In the rear the bolts are the same. The part mounted to the car is not as rigid. It is also a little more exposed to the elements and rusts a little faster. These will rust up and rip the bracket off the car. |
yrret7 |
Sep 27 2010, 09:30 AM
Its been a while, but, I think there is a plastic bushing that the bolt goes thru. Steel bolt in a steel hole. Often freezes up from rust. This is a place where there should be a place to lubricate. The bolt head doesn't allow easy lubricating. The hinges are a little loose on the cars I have seen. Better loose than frozen. In the rear the bolts are the same. The part mounted to the car is not as rigid. It is also a little more exposed to the elements and rusts a little faster. These will rust up and rip the bracket off the car. There is no rust on it at all. It just seems that the the bolt or the hinge bolt hole has changed in size. If I put a washer on the bolt it would prevent the hinge from moving. The shoulder of the bolt would not touch the bracket on the car. I guess i might have to find new bolts and hinges. I might be able to find the bolts but the hinges???? |
yrret7 |
Sep 27 2010, 09:49 AM
Its been a while, but, I think there is a plastic bushing that the bolt goes thru. Steel bolt in a steel hole. Often freezes up from rust. This is a place where there should be a place to lubricate. The bolt head doesn't allow easy lubricating. The hinges are a little loose on the cars I have seen. Better loose than frozen. In the rear the bolts are the same. The part mounted to the car is not as rigid. It is also a little more exposed to the elements and rusts a little faster. These will rust up and rip the bracket off the car. There is no rust on it at all. It just seems that the the bolt or the hinge bolt hole has changed in size. If I put a washer on the bolt it would prevent the hinge from moving. The shoulder of the bolt would not touch the bracket on the car. I guess i might have to find new bolts and hinges. I might be able to find the bolts but the hinges???? The issue is that the hood just about touches the fender on one side and has a half inch gap on the other side. In order to move it over I had to enlarge the holes in the hinges that bolts to the hood. The issue now is the play from the pivot point on the hinge. With the hood off and the spring off there is half an inch play. What to do. ????? Thanks for all your replys!!!! I will try putting washers tonight and see if it helps. |
Bartlett 914 |
Sep 27 2010, 10:20 AM
The bolt is special. It is a shoulder bolt. Adding washers will prevent the hinge from operating. The hinge is steel on steel. The diameter is 12mm. Is this the bolt you have? The fit is pretty close. Measure the shoulder diameter on your bolt. It may be worn out. It could also be the hinge hole. There are plenty available. Ask on the parts forum.
Attached image(s) |
Bartlett 914 |
Sep 27 2010, 10:22 AM
Here is a better picture of the bolt.
Attached image(s) |
yrret7 |
Sep 27 2010, 10:39 AM
Here is a better picture of the bolt. Thats the bolt!!!! I will measure the bolt. Thanks for posting the picture!!!!!! I'm not sure how to do that yet. I'm a newbee and just bought the 914 le a few months back. The gap is driving me nuts . A great big thankyou to everyone to all who replyed. !!!!!!! |
Spoke |
Sep 27 2010, 11:29 AM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
The issue is that the hood just about touches the fender on one side and has a half inch gap on the other side. In order to move it over I had to enlarge the holes in the hinges that bolts to the hood. The issue now is the play from the pivot point on the hinge. With the hood off and the spring off there is half an inch play. What to do. ????? Thanks for all your replys!!!! I will try putting washers tonight and see if it helps. The hinge support plates that the bolts tie into are adjustable. If your hood is low or high some adjustment is had with the support plates. Show a pic or 2 so we can help you better. We don't like to read around here. |
SirAndy |
Sep 27 2010, 11:38 AM
Resident German Group: Admin Posts: 41,676 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
With the spring tension removed, the hinges will feel lose. In fact, even with the springs on them, they will easily move left/right.
That is by design. If you are having trouble aligning your hood, your problem is most likely elsewhere. The bolts that hold the hood to the hinges allow for fine adjustment. Also make sure the hinge itself is not bend. (IMG:style_emoticons/default/welcome.png) Andy |
yrret7 |
Sep 27 2010, 12:24 PM
The issue is that the hood just about touches the fender on one side and has a half inch gap on the other side. In order to move it over I had to enlarge the holes in the hinges that bolts to the hood. The issue now is the play from the pivot point on the hinge. With the hood off and the spring off there is half an inch play. What to do. ????? Thanks for all your replys!!!! I will try putting washers tonight and see if it helps. The hinge support plates that the bolts tie into are adjustable. If your hood is low or high some adjustment is had with the support plates. Show a pic or 2 so we can help you better. We don't like to read around here. Thanks for you reply!!! It's all apart now but someone has posted some pictures of the hinge and bolt. The up and down movement of the hood was ok . It's the side to side movement thats not. I have inlarged the holes in the hood to be able to shift it over to the side . The issue I was having was the hinges had a lot of play at the pivot point. Someone just posted after you stated that this is normal. The fender was replaced at some point. It looks like if I can get it centred the gaps will be right. I will find out tonight when I reinstall the hood. I thought the hinges would not have any play!!!! I don't know how to post pictures yet. I will try to figure that tonight. I'm super impressed buy the amount of help that I have received. What a great group that I joined!!!!! |
yrret7 |
Sep 27 2010, 12:34 PM
With the spring tension removed, the hinges will feel lose. In fact, even with the springs on them, they will easily move left/right. That is by design. If you are having trouble aligning your hood, your problem is most likely elsewhere. The bolts that hold the hood to the hinges allow for fine adjustment. Also make sure the hinge itself is not bend. (IMG:style_emoticons/default/welcome.png) Andy Thanks Andy!! One of the hinges had a small bend in it but i removed it. The hood hinges with the springs installed with no hood on seems to pull to the side which is where the hood has about 1/16 of inch clearence. When I reinstall the hood i'm afraid its going to pull the hood over even though i've enlarged the holes and shifted the hood over enough so that it would sit perfect. This would be caused by the play in the hinges. I will know tonight if it works. Terry |
SirAndy |
Sep 27 2010, 01:08 PM
Thanks Andy!! One of the hinges had a small bend in it but i removed it. The hood hinges with the springs installed with no hood on seems to pull to the side which is where the hood has about 1/16 of inch clearence. When I reinstall the hood i'm afraid its going to pull the hood over even though i've enlarged the holes and shifted the hood over enough so that it would sit perfect. This would be caused by the play in the hinges. I will know tonight if it works. Here's what a good body shop would do ... With the hood firmly attached to the hinges, open the hood all the way and slowly push it from the side (close to the hinges) in the direction you need it to go. Push it further than it needs to go as it will come back towards you. Do this until the hood stays in the right place. (IMG:style_emoticons/default/beerchug.gif) Andy |
swl |
Oct 2 2010, 07:53 AM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
Show us the car yrret! (IMG:style_emoticons/default/wink.gif)
here's a link to the pic posting instructions. Make sure the resolution isn't too high. If you have problems I'm sure you could find a geeky neighbor to help (IMG:style_emoticons/default/smile.gif) http://www.914world.com/bbs2/index.php?showtopic=13637 |
Lo-Fi Version | Time is now: 8th June 2024 - 02:48 AM |
