Nead a source for fastners for engine lid/trim |
Krieger |
Oct 8 2010, 03:58 PM
Advanced Member Group: Members Posts: 4,723 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
The rubber donuts that hold the engine grill to the engine lid. Does not need to be oem. I do not want to use AA and or pay 2 something each. I have a GT style lid and need more than usual. Also the 3 metal clips that hold the center trim piece on the rear of the Targa bar. Mine are kinda rusty.
TheCabinetmaker |
Oct 8 2010, 04:06 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I doubt your gonna find them for under 2 bucks.
azbill |
Oct 8 2010, 04:29 PM
Member Group: Members Posts: 455 Joined: 26-July 04 From: Glendale, Az Member No.: 2,403 Region Association: Southwest Region |
I think you need cheese head screws. Check a VW shop they should have them for a reasonable price. AA IS VERY PROUD of their parts.
dr914@autoatlanta.com |
Oct 8 2010, 04:42 PM
914 Guru Group: Members Posts: 7,887 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
The correct ones are the factory ones of which we have many in stock of course The aftermarket ones are the steel with the putty in them that work fine but do not look correct. They are just over a dollar each. The center targa lateral finishing strip uses only three of the clips and again they are only factory as the used are like you said, rusty. This has become a popular item recently so we have plenty of these in stock as well. Its the place that stocks the little needed hardware pieces that makes the difference.
The rubber donuts that hold the engine grill to the engine lid. Does not need to be oem. I do not want to use AA and or pay 2 something each. I have a GT style lid and need more than usual. Also the 3 metal clips that hold the center trim piece on the rear of the Targa bar. Mine are kinda rusty. |
bandjoey |
Oct 8 2010, 05:03 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Even the cheap tin ones at PepBoys are $1 each.
Mikey914 |
Oct 8 2010, 05:29 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
James has them at AP-
Emblem Retainer Sets$7.5click to shrink click to enlargeThis is a set of 6 3mm speed nuts, they are the correct size for your factory 914 script and emblems. 3mm is not too tight as to weaken and cut into the posts and is not too loose that they fall off. There is also a rubber washer attached to help keep emblem holes from leaking. 3mm Retainers set of 6 $7.50set of 12 $12.50 http://www.914ap.com/products.php |
Krieger |
Oct 8 2010, 06:19 PM
Thanks guys. OEM is not that big of a deal for me on this car.
computers4kids |
Oct 8 2010, 06:36 PM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
James has them at AP- Emblem Retainer Sets$7.5click to shrink click to enlargeThis is a set of 6 3mm speed nuts, they are the correct size for your factory 914 script and emblems. 3mm is not too tight as to weaken and cut into the posts and is not too loose that they fall off. There is also a rubber washer attached to help keep emblem holes from leaking. 3mm Retainers set of 6 $7.50set of 12 $12.50 http://www.914ap.com/products.php These won't work for the grill--too loose, but great for the emblems. |
Lo-Fi Version | Time is now: 1st June 2024 - 12:13 PM |
