Plumbing remote oil filter/cooler on a 2270?, Where to plumb out of T4 case? |
jasons |
Oct 27 2010, 08:27 AM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
I am having a 2270 built. Currently the oil galleys are tapped on the front of the case near the oil filter console location. This is where the oil will return. The plan is to run a remote oil filter and probably a front mounted oil cooler. The question is should I get oil output right off the front of the pump with a T1 pump cover or should I just plumb it out of the tapped oil galley on the front of the case? I know the T1 cover requires motor mount mods.
pcar916 |
Oct 27 2010, 08:41 AM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
jasons |
Oct 28 2010, 07:37 AM
JmuRiz |
Oct 28 2010, 07:50 AM
914 Guru Group: Members Posts: 5,434 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Mine just has a console between the oil filter and the engine...probably the easiest way to get a connection.
jasons |
Oct 28 2010, 08:00 AM
Mine just has a console between the oil filter and the engine...probably the easiest way to get a connection. Sure that's a common way to add an external oil cooler. But since my case is apart and the galleys have been drilled and tapped, I can go right off the case and just eliminate the oil filter console. With a remote filter mount I can run a larger filter too. |
ConeDodger |
Oct 28 2010, 08:08 AM
Apex killer! Group: Members Posts: 23,616 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
If you don't want to reinvent the wheel, you could use the full-flow oil pump the TypeIV Store sells. It has a cover that has two fittings for your oil lines already tapped. You do need to slightly modify the passenger side motor mount flange.
Jake Raby |
Oct 28 2010, 08:09 AM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Mine just has a console between the oil filter and the engine...probably the easiest way to get a connection. Sure that's a common way to add an external oil cooler. But since my case is apart and the galleys have been drilled and tapped, I can go right off the case and just eliminate the oil filter console. With a remote filter mount I can run a larger filter too. Yes, thats the best way. It is what we do on every build that gets full flow oiling. |
Mark Henry |
Oct 28 2010, 08:20 PM
If you do a proper full flow system you need to modify the one engine mount to clear the line/fitting coming out of the pump cover.
jasons |
Oct 29 2010, 07:57 AM
If you do a proper full flow system you need to modify the one engine mount to clear the line/fitting coming out of the pump cover. Yeah, I know you were selling those or offering the service. Do you still do that? I don't see oil pump kits in the type4store. I know they used to be there. |
Lo-Fi Version | Time is now: 12th June 2024 - 04:58 AM |
