Zaney |
Deuchland en der Haus ![]() ![]() Group: Members Posts: 461 Joined: 1-March 04 From: Engine 11 Redmond, WA Member No.: 1,738 Region Association: Pacific Northwest ![]() |
Silly me. (IMG:style_emoticons/default/chair.gif) I can not find the measurements for the seat hinge mounts that I took before replacing the floorpan.
I would be most grateful for anyone with their stock seats already out who could grab the measurements for me (IMG:style_emoticons/default/smile.gif) Or point me to a thread with this info already in it! Just let me know where they are referenced from in the car and I can figure it out. Thanks!!! (IMG:style_emoticons/default/smilie_pokal.gif) Nate |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
I checked on two of the cars in the shop. Here's two measurements so you can double check.
4.5" from the back wall to the rear edge of the plate. 7.25" from the back wall to the center of the hinge pivot shaft. |
Zaney |
Thanks Mark!!!!
(IMG:style_emoticons/default/beer.gif) |
Jeff Hail |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 ![]() |
I used the crossmember as reference.
Attached image(s) ![]() |
jmmotorsports |
Member ![]() ![]() Group: Members Posts: 308 Joined: 15-August 06 From: Kelso,Wa. Member No.: 6,658 Region Association: Pacific Northwest ![]() |
I bolt the plates with the hinge to the slider. Put the height adjuster in one of the notches in the part that is bolted to the crossmember,square everything up and weld them in. Works for me.
Jerry |
Lo-Fi Version | Time is now: 11th June 2024 - 04:44 AM |
