SS braided hose, same or not same |
machina |
Apr 23 2004, 03:20 PM
Advanced Member Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
There is a huge industrial hose place couple miles from me. They have this stainless braided hose. Has same pressure capacity and ID, OD, temp as the aeroquip, earls, etc...
Do you think this can work with the AN fittings? I'll bet all these companies buy it from these guys anyway. dr Attached image(s) |
ChrisFoley |
Apr 23 2004, 05:28 PM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
The catalog spread says its Teflon hose. That isn't anything like the Aeroquip, etc. rubber hose.
lapuwali |
Apr 23 2004, 05:34 PM
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
However, it is very like the brake hose supplied by several vendors for fabricating your own stainless brake lines with fittings from Earl's, et al.
rdracrdave |
Apr 23 2004, 09:22 PM
Newbie Group: Members Posts: 34 Joined: 5-May 03 From: Cincinnati,Ohio Member No.: 653 |
Actually Aeroquip does make fittings for teflon lined metal braided hose. the fittings that you see in your hot rod/ racing catalog are usually for rubber lined hose .
There is a company selling aeroquip fittings on ebay ,in the industrial section , that has those kinds of fittings . do a search for aeroquip and you may come up with the ends you need . BTW the teflon hoses arent as flexable as the rubber lined hoses. Good luck Dave |
lmcchesney |
Apr 24 2004, 06:39 AM
Member Group: Members Posts: 488 Joined: 24-November 03 From: Ocala, Fl. Member No.: 1,381 Region Association: None |
Guys,
I found this site which sells Blemished AN fittings at good prices. http://www.home.earthlink.net/~kcroussin/ L. McC |
Jake Raby |
Apr 24 2004, 08:13 AM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
If anyone is interested I have 3 rolls of -8 Teflon Braided hose that I'll sell cheap.... It came from an aircraft project I worked with a few years ago and we never changed the hoses that we were going to swap out... I'll sell it for 100.00 a roll, and that is dirt cheap. I believe there is 20 yards per roll!
Lo-Fi Version | Time is now: 1st June 2024 - 10:30 AM |
