Driver's door key question? |
KaptKaos |
Dec 4 2010, 11:55 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
If the driver's door is lock, I can insert the key and rotate it, but it doesn't unlock the door.
If I go through the passenger side, I can unlock the door, and the door handle works just fine from the outside. I think I have read that there is a little plastic thingie that breaks. Anyone have better details than that? TIA |
markb |
Dec 5 2010, 01:32 AM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
Go to my tech article in the info section (or my sig), look at the third picture, the one with the screwdriver. That's the piece that is broken in your handle.
KaptKaos |
Dec 5 2010, 10:47 AM
Thanks Mark.
Are replacements of those available? |
Tom_T |
Dec 5 2010, 12:06 PM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
Yes, in both plastic & metal IIRC, from the usual sources. Not sure if GPR carries them, or if Mikey914 might make a better repro one in metal. Might as well buy 2 for when the next one goes on the other side at some point. (IMG:style_emoticons/default/dry.gif)
KaptKaos |
Dec 5 2010, 03:25 PM
KaptKaos |
Dec 6 2010, 10:01 AM
Anyone have a link for these?
dr914@autoatlanta.com |
Dec 6 2010, 10:54 AM
914 Guru Group: Members Posts: 7,894 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Yes probably the door latch cam. That was the very first part we ever had manufactured and have sold literally thousands of them! Made from Nylon 11 and guaranteed for life, they are easily replaced and save expensive replacement of the exterior door latch! http://www.autoatlanta.com/detail.php?Part...al_number=23075
If the driver's door is lock, I can insert the key and rotate it, but it doesn't unlock the door. If I go through the passenger side, I can unlock the door, and the door handle works just fine from the outside. I think I have read that there is a little plastic thingie that breaks. Anyone have better details than that? TIA |
markb |
Dec 6 2010, 11:51 AM
Yes probably the door latch cam. That was the very first part we ever had manufactured and have sold literally thousands of them! Made from Nylon 11 and guaranteed for life, they are easily replaced and save expensive replacement of the exterior door latch! http://www.autoatlanta.com/detail.php?Part...al_number=23075 If the driver's door is lock, I can insert the key and rotate it, but it doesn't unlock the door. If I go through the passenger side, I can unlock the door, and the door handle works just fine from the outside. I think I have read that there is a little plastic thingie that breaks. Anyone have better details than that? TIA If the key doesn't unlock the door, it's not the cam, it's the actuator. Nice plug, tho, George. |
r_towle |
Dec 6 2010, 12:07 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
This piece is what you may need.
This thing unlocks the door. The actuator opens the door (once its unlocked) If you are going to the trouble, I would suggest you replace both pieces at the same time...the actuators are cheap and they do break with age. The little piece (in the picture below) is fast to replace...as you see it just a screw and spring. The actuator takes a bit more time, but its really simple to do once you have the lock in hand. Take the door panel off and remove the whole latch. Do the work on the bench and put it back in. There is a screw hidden behind the rubber gasket on the side of the door that holds the unit in place... Once the door panel is off, you can remove the handle in a few minutes...replace the parts in less than 30 minutes and be all done with the project in an hour or so, depending upon how many beers you have, and how many times your wife comes out to bother you. Rich Attached thumbnail(s) Attached image(s) |
KaptKaos |
Dec 7 2010, 01:12 AM
I'll replace both wear items and buy doubles for the other side too.
Problem is, I can't find the actuator anywhere. Someone got a link? |
markb |
Dec 7 2010, 12:19 PM
I'll replace both wear items and buy doubles for the other side too. Problem is, I can't find the actuator anywhere. Someone got a link? We have the new door cams ($13.99 each), and I have a box of actuators, I can throw a couple in the box for you (freebies), should you buy the cams from us. |
KaptKaos |
Dec 7 2010, 11:56 PM
Thanks Mark. I will be in touch soon =)
KaptKaos |
Dec 26 2010, 06:24 PM
So I did a little recon today (along with my hydro-locking problem) and took off the door panel on the driver's side to gain access to this handle.
The nut at #1 in the picture is stuck to the stud and the nut and the stud rotate together. Therefore, I believe that the stud is broken at the handle somehow. It won't back out. Unless someone has a better idea, I think I will need to cut that nut off of there. The allen bolt at position 2 came out just fine. Any suggestions on what to do with #1? TIA |
URY914 |
Dec 26 2010, 07:32 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,038 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Pretty common problem. Cut it off. When you break the tab off send it to me and I can fix it. (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 8th June 2024 - 03:03 AM |
