| john grier |
Dec 7 2010, 07:29 PM
Member ![]() ![]() Group: Members Posts: 304 Joined: 27-June 04 From: Hermitage, Tn Member No.: 2,265 Region Association: South East States |
Yeah it's cold here!
And I am driveing my 914 as a daily driver. Is there anything that I should be concerned with? The only proplem that I have noticed is that it takes awhile to shift right, as it is cold and has to warm up. And the door does not want to close the way it should. Sometimes. |
| SLITS |
Dec 7 2010, 07:30 PM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
That 90W oil in the tranny takes a while to get liquid in cold temps.
| Gint |
Dec 7 2010, 07:31 PM
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,106 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I drive mine in the winter if snow isn't expected. All the time in fact. You need to make sure your drive is long enough yo get the oil up to full temp. Other than that, nothing to worry about as far as I'm concerned.
| r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
go to 70 weight gear oil in the tranny for the winter.
Start it in neutral with the clutch out, let it warm up a bit till the gear oil gets warm. Funny how you find things like the door that wont close when 20 degree air is coming in....lol Fix the door. Rich |
| Elliot Cannon |
Dec 7 2010, 07:39 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
It's sure a pain in the a$$ when it gets cold. I had to put the roof back on this month. (IMG:style_emoticons/default/lol-2.gif)
| SLITS |
Dec 7 2010, 07:43 PM
It's sure a pain in the a$$ when it gets cold. I had to put the roof back on this month. (IMG:style_emoticons/default/lol-2.gif) You mean you actually left the warming blanket and your house to go outside? |
| john grier |
Dec 7 2010, 07:57 PM
I think I will drive it a few more days.
Most likely they will start laying down salt brine next week. I will not drive it then. I plan on putting it up for the winter this weekend. How long should it idle to get the tranny fluid warm? Or do you have to drive it to warm it up? |
| smontanaro |
Dec 7 2010, 08:03 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
Fix the door. Any suggestions about potential cause/solution? I've been meaning to post about this problem, but as the snow has flown here in Chicago, my car is in for the winter, so I didn't worry about it too much. My right side door has always been a bit recalcitrant. Now I can't get it to close at all. I can manually flip the little horsehoe thingie (latch?) and get it to release with the inside or outside handle, but it won't engage the post on the door jamb. I think everything is in adjustment. When I messed with it a bit a couple years ago I couldn't get anything to move around anyway. Skip |
| john grier |
Dec 7 2010, 08:19 PM
All I was told about the door was that I need to lubricate it.
Before the cold weather it would close with the touch of a finger tip. |
| 914 shifter |
Dec 7 2010, 08:53 PM
airhead ![]() ![]() Group: Members Posts: 266 Joined: 28-August 10 From: ny/nj Member No.: 12,111 Region Association: North East States |
shift early, and double clutch till she warms up (IMG:style_emoticons/default/type.gif)
| MDG |
Dec 7 2010, 09:08 PM
Wolf in wolf's clothing. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,653 Joined: 3-February 09 From: Toronto Member No.: 10,018 Region Association: None |
My first 914 was my daily driver for most of the 80s. I'd let it idle for just a few minutes only then easy shifts until it warmed itself up. It never let me down. December through March I'd take the Mahles off and put snow tires on an old set of steel rims. Awesome!!
Of course the last time I went to jack it up it pretty much broke in half so . . . snow driving in a 914: good. road salt in a 914: not good. your results may vary. |
| Richard Casto |
Dec 7 2010, 10:06 PM
Blue Sky Motorsports, LLC ![]() ![]() ![]() Group: Members Posts: 1,465 Joined: 2-August 05 From: Durham, NC Member No.: 4,523 Region Association: South East States |
Ahhhh memories. In the late 1980's a 914 was my daily driver. It had no heat and I had a 45 minute drive from home to college. Nothing like driving with the window cracked a bit to prevent the windshield from fogging or icing up on the inside on a below freezing winter day.
| jd74914 |
Dec 7 2010, 11:02 PM
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,870 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Ahhhh memories. In the late 1980's a 914 was my daily driver. It had no heat and I had a 45 minute drive from home to college. Nothing like driving with the window cracked a bit to prevent the windshield from fogging or icing up on the inside on a below freezing winter day. (IMG:style_emoticons/default/agree.gif) Or driving 45 minutes from work to your dorm without heat in single digit temperatures. Cold, like fingers turning blue inside your lobster gloves, cold. After doing that for a while I really appreciate my new car. That said, I'll take a 914 with snow tires over any other car in the snow. (IMG:style_emoticons/default/biggrin.gif) Rich is right, the 90W gear oil does get pretty viscous. It literally would take me 45 minutes of driving to warm it up. (IMG:style_emoticons/default/huh.gif) |
| SirAndy |
Dec 7 2010, 11:35 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,453 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
| hot_shoe914 |
Dec 7 2010, 11:42 PM
on ramp passer ![]() ![]() ![]() ![]() Group: Members Posts: 3,807 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
Christine loves the snow!
| jd74914 |
Dec 8 2010, 12:25 AM
Oh yeah... remember to clean the snow from the wheel wells and rocker panels. At least on my car it builds up pretty quickly!
| r_towle |
Dec 8 2010, 11:12 AM
Fix the door. Any suggestions about potential cause/solution? I've been meaning to post about this problem, but as the snow has flown here in Chicago, my car is in for the winter, so I didn't worry about it too much. My right side door has always been a bit recalcitrant. Now I can't get it to close at all. I can manually flip the little horsehoe thingie (latch?) and get it to release with the inside or outside handle, but it won't engage the post on the door jamb. I think everything is in adjustment. When I messed with it a bit a couple years ago I couldn't get anything to move around anyway. Skip Start a thread, show pics of your door closed, the gap etc. I dont use litheum grease anymore...it gets to dirty. Old grease can turn into stone when its really cold...almost the consitancy of frozen peanut butter... Remove the latch and clean out all the old grease...then lube it. I use teflon lubricant I get at the bicycle store.....its magic. Its called Tri-Flow Rich |
| jt914-6 |
Dec 8 2010, 11:25 AM
Driving & working on teeners 41 years ![]() ![]() ![]() Group: Members Posts: 1,787 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
When I lived in Salt Lake City in about 15 degree weather I had the CV bolts break leaving a stop light. It fell on the shift bar and bent it...A pic of my cold 914 many years ago....
| Cevan |
Dec 10 2010, 09:12 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
It was 6 degrees when I left my house this morning. Brrrrr.
| r_towle |
Dec 10 2010, 09:21 AM
It feels like it is still 6 degrees out.
Dang.... I noticed that with the right tires, these cars are alot of fun, but you really need to raise up the suspension or they can easily get high centered on about 6 inches of snow... Its kinda like a snowboard. I am enjoying my nice warm bmw this year, but the rear wheel drive makes it very interesting for me...its been a long time since I had RWD in the winter... I have the VAN for backup and its FWD and a tank in the snow, so I figure I will take that when its deep. Rich |
Lo-Fi Version | Time is now: 3rd March 2026 - 06:58 PM |
