spark plug gap for a six conversion, with aftermarket CDI and coil |
rfuerst911sc |
Dec 26 2010, 05:37 AM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
My GT clone has a 1978 911SC 3.0 with stock internals. The ignition distributor was reworked by Jerry Woods to maximize performance with the Weber carbs. I have a Mallory HI-IV ignition box with a MSD Blaster coil. Plug wires are OEM braided with Bosch copper plugs. Car runs quite well but I'm curious what spark plug gap is suggested ? I've read anywhere from stock to .060 and everything in between. If I remember correctly I currently have them just a little larger than stock. So what are you guys using for plug gaps ?
J P Stein |
Dec 26 2010, 06:58 AM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
I ran .050 gap.
A couple other comments that you may take or leave as desired. I used the MSD Hi vibration coil. It is potted and can be used in any attitude. Oil filled coils should be mounted upright lest they spray oil all over God's creation. Big plug gaps need big voltage. Normal wires oft times can't handle the increased voltage (36000+ v). The big gaps "burn through" the rich mixtures due to Webers and prevent plug fouling. I found NGK copper plugs work best. Plugs used to be "one is as good as another" to me....no more. This was hard won data from some years back. Bout 6 months of dicking around with a motor that just didn't run to my expectations. |
Lo-Fi Version | Time is now: 7th June 2024 - 09:10 AM |
