DanT |
Going back to the Dark Side! ![]() ![]() ![]() ![]() Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None ![]() |
(IMG:style_emoticons/default/sad.gif)
so it there an easy way to do this without major surgery? thanks (IMG:style_emoticons/default/blink.gif) |
tradisrad |
Senior Member ![]() ![]() ![]() Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California ![]() |
remove the front bumper and you can get to the latch. 4 bolts, well maybe not with that '75 bumper.
Rod |
Senior Member ![]() ![]() ![]() Group: Members Posts: 617 Joined: 1-January 08 From: Farnham UK Member No.: 8,526 Region Association: England ![]() |
Yes there is - under the bumper is a screwhole - get a screwdriver in there and it will pop open. I'll try and find a pic for you...
You need to remove the bumper btw (IMG:style_emoticons/default/sad.gif)(IMG:style_emoticons/default/sad.gif) |
sfrenck |
Member ![]() ![]() Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region ![]() ![]() |
Haynes manual Chapter 10 has the procedure and a pic of the hole (Fig 10.15 in my copy)
johannes |
Club Porsche 914 France member since 2005 ![]() ![]() ![]() ![]() Group: Members Posts: 3,092 Joined: 13-January 06 From: France Member No.: 5,409 Region Association: France ![]() |
DanT |
thanks guys...was able to have my daughter pull with both hands on the release handle while I pushed and pulled on the front of the hood....the mechanism was releasing part of the way but not all the way....finally after a couple of tries, the hood popped open...
I then readjusted the latch, took all the slack out of the release cable. Several dry runs just setting the latch by hand as the trunk was open...worked fine. Finally re-shut the hood and it worked better than it has since I reassembled things... Should have taken the time to readjust during reassembly (IMG:style_emoticons/default/smile.gif) |
Rod |
thanks guys...was able to have my daughter pull with both hands on the release handle while I pushed and pulled on the front of the hood....the mechanism was releasing part of the way but not all the way....finally after a couple of tries, the hood popped open... I then readjusted the latch, took all the slack out of the release cable. Several dry runs just setting the latch by hand as the trunk was open...worked fine. Finally re-shut the hood and it worked better than it has since I reassembled things... Should have taken the time to readjust during reassembly (IMG:style_emoticons/default/smile.gif) Well done (IMG:style_emoticons/default/piratenanner.gif) |
DanT |
turning the steering wheel to full lock will give you more room to access bumper bolt in fender welll on each side. rightie tightie lefty loosey (IMG:style_emoticons/default/happy11.gif) Bumper bolts on a '75 are out in front under the bumper where all can get easy access, one of the pluses of late bumpers (IMG:style_emoticons/default/biggrin.gif) |
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
Squirt some lube into the release cable housing. Helps a lot.
DanT |
Squirt some lube into the release cable housing. Helps a lot. yes it does, and I had lubed the cable several months ago...I was pretty sure the latch was just not releasing completely and that was the case...now all the slack is removed and the latch is readjusted properly. |
timofly |
Member ![]() ![]() Group: Members Posts: 168 Joined: 21-February 09 From: VA Member No.: 10,082 Region Association: MidAtlantic Region ![]() |
Squirt some lube into the release cable housing. Helps a lot. yes it does, and I had lubed the cable several months ago...I was pretty sure the latch was just not releasing completely and that was the case...now all the slack is removed and the latch is readjusted properly. Also, be sure that the cable is secured at all the factory points. Too much flex will prevent you getting the leverage you need to open the mechanism. BTDT. |
Tom_T |
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California ![]() ![]() |
For future reference Dan, the small hole dead center of the front panel in the pic of my 73 below gives you access with a flat-head screwdriver to pop the emergency release pin on the lower latch mechanism inside (once you get the bumper off) & is there on all MYs.
![]() (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 8th July 2025 - 03:29 PM |
