| KELTY360 |
Jan 5 2011, 01:43 PM
914 Neferati ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,186 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest
I need to replace my + battery cable. It has a threaded lug on the terminal that holds some smaller wires. Haven't been able to find a cable with this feature so I need some advice on the best way to handle these connections. What are my options?
| dr914@autoatlanta.com |
Jan 5 2011, 01:48 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,233 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
WE have the correct one, either just the terminal end or the complete wire down to the starter with the end on it.
I need to replace my + battery cable. It has a threaded lug on the terminal that holds some smaller wires. Haven't been able to find a cable with this feature so I need some advice on the best way to handle these connections. What are my options? ![]() |
| KELTY360 |
Jan 5 2011, 01:52 PM
WE have the correct one, either just the terminal end or the complete wire down to the starter with the end on it. I need to replace my + battery cable. It has a threaded lug on the terminal that holds some smaller wires. Haven't been able to find a cable with this feature so I need some advice on the best way to handle these connections. What are my options? ![]() I emailed through your online catalog last fall and was told that the cable AA sold did not have the lug as shown in the picture. Is that true? or, is the picture I posted not a correct part? |
Jan 5 2011, 02:07 PM
No not the lug like that but the original German crimp on end with the exact same cinching bolt and the extra red wires attach under the nut, OR the collar of the cable end can be tapped. The problem with the ends out there is that they are a clamp on rather than a crimp on and look LIKE HELL when installed. This one does not.
| Tom_T |
Jan 5 2011, 02:08 PM
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California
Marc, I think Jeff Bowlsby does them along with his other engine bay harnesses.
Shoot him a PM. |
| KELTY360 |
Jan 5 2011, 02:12 PM
| kconway |
Jan 5 2011, 02:45 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
| dflesburg |
Jan 5 2011, 03:12 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,722 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
FLAPS.
| realred914 |
Jan 5 2011, 05:28 PM
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
wonder if there was more than one type on stock 914's I have a brass terminal on mine, with the lug for the small wires on the top rather than on the side as shown by the kelty guy
a larger ring terminal would allow putting the small wires on the clamping bolt, not stock, but usable. so what type(s) of terminal was offered originally??????????????????? |
| KELTY360 |
Jan 5 2011, 05:42 PM
wonder if there was more than one type on stock 914's I have a brass terminal on mine, with the lug for the small wires on the top rather than on the side as shown by the kelty guy a larger ring terminal would allow putting the small wires on the clamping bolt, not stock, but usable. so what type(s) of terminal was offered originally??????????????????? (IMG:style_emoticons/default/agree.gif) I'm wondering the same thing. |
| 914Sixer |
Jan 5 2011, 08:30 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,467 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
The cable that is in the picture is no where close to stock. Some one has made yours up.
| detoxcowboy |
Jan 5 2011, 09:04 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
There are alot of choices for battery cable terminals, but you will have to make your own, usually buying a longer one than what your using and cutting off to lenght on terminal side you won't be using then install your chosen one, or if you have length on the one you have pictured, cut the head off, put another on if the rest of the cable is ok to you.. There are all kinds on line not just at your flaps or car audio installer.. ( gold plated, led digital voltage read out, and python stamped on it (IMG:style_emoticons/default/drooley.gif) )
while your at it you could re-do the red wire terminals too, they look at bit exposed and haggard.. there are more but here is a start linky.. http://www.jcwhitney.com/battery-cables-an.../c921j1s17.jcwx |
| Drums66 |
Jan 6 2011, 05:28 PM
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
....Just get it from George at AA (IMG:style_emoticons/default/confused24.gif)
( or just more collusion?) (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/bye1.gif) |
| jd74914 |
Jan 6 2011, 05:46 PM
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,876 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
FLAPS. (IMG:style_emoticons/default/agree.gif) I got one just like George is describing from my local Autozone. |
| detoxcowboy |
Jan 6 2011, 05:51 PM
Member Jeff Bowlsby has the factory cable that your looking for (used) in his parts for sale section of his website (linky) or here in member vendors section under wiring harnesses..
linky.... http://members.rennlist.com/914_canam/ |
| bandjoey |
Jan 6 2011, 10:25 PM
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,935 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Quick down and dirty easy. AutoZone Clamp. Bundle the accessory wires with a ring terminal, bolt them down to the clamp bolt. Sorry for the cell phone photo but you can see.
| 76-914 |
Jan 7 2011, 10:58 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,878 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
I separated mine out to improve future electrical diagnostics. (in my mind, anyway)
| IronHillRestorations |
Jan 7 2011, 12:28 PM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,927 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
Here's what the factory used. I'd love to be able to get a few.
Attached thumbnail(s) |
| KELTY360 |
Jan 7 2011, 08:27 PM
You guys have given me lots of good ideas. I found some Bolt Extenders that look promising.
Battery Bolt Extenders |
Jan 8 2011, 09:52 AM
That's what I've been putting on the ones I make, but the terminal is larger than M6.
Lo-Fi Version | Time is now: 17th April 2026 - 01:39 AM |
