| tornik550 |
Jan 9 2011, 10:16 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I decided earlier today to use a bus case for my rebuild. I had it laying around, it is a very nice case. I started to take the oil galley plugs out just like I have several times before on 914 cases. I ran into an issue that I hadn't on previous cases.
On the galley plug behind cylinder #1 near the flywheel side, there is a metal tube that runs from the rear cam bearing to the mechanical fuel pump boss. The tube blocks the galley and makes it so I cannot tap the hole. Since I am not running a mechanical fuel pump, can I just drill through the metal tube so that I can tap the galley hole? Attached image(s)
| bam914 |
Jan 9 2011, 10:48 PM
Member ![]() ![]() Group: Members Posts: 342 Joined: 23-November 03 From: Atlanta, Ga Member No.: 1,378 Region Association: None |
You will need to remove the bronze bushing and tap it too.
| Mark Henry |
Jan 10 2011, 07:41 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
You can just punch the tube out. You have to tap and plug both sides (pic#2 and 3) of the pump rod hole. Then you must make a block off plate for the pump mount.
You also need a block off (on the other end) for the oil fill tube and you'll have to figure out a dipstick. |
| Jake Raby |
Jan 10 2011, 08:37 AM
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
You should have read my article before you started. That plug didn't need to be removed since uts a fuel pump case.
As Mark states, yu'll have to tap both sides of this galley, else you'll have no oil pressure! |
| tornik550 |
Jan 10 2011, 08:55 AM
You should have read my article before you started. That plug didn't need to be removed since uts a fuel pump case. As Mark states, yu'll have to tap both sides of this galley, else you'll have no oil pressure! I am actually trying to do everything right this time so I actually did read the article. The problem was that I read it prior to doing the plugs on my 914 case. I didn't even pay attention to the part about the bus case because it was irrelevant at the time. Oh well. |
| mrbubblehead |
Jan 10 2011, 09:23 AM
Twodollardoug ![]() ![]() ![]() Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
| Jake Raby |
Jan 10 2011, 10:52 AM
All my articles are on my forums.
Not all bus cases have a fuel pump, just 72-74 carbureted engines.. |
Lo-Fi Version | Time is now: 3rd March 2026 - 06:22 PM |
