Weather stripping for front trunk lid |
NJ914Guy |
Jan 15 2011, 08:01 AM
Member Group: Members Posts: 150 Joined: 30-December 10 From: Deptford, NJ Member No.: 12,546 Region Association: MidAtlantic Region |
I see a lot of 914's with front trunk lids that sit just a little bit high, especially around the headlights. This is also an issue on my new 914. PO claims the problem is due to a poor fitting (aftermarket) weather strip.
I want to correct this on my car. Which parts vendor has the best fitting front trunk weather strip? I am told tha 914rubber is very good quality? Any tips for removal of the old and installation of the new is much appreciated. Thanks! |
dr914@autoatlanta.com |
Jan 15 2011, 09:05 AM
914 Guru Group: Members Posts: 7,887 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I would not say that the trunk lid problem is a poor fitting hood seal (although the Tasker variety that everyone sells does not have the molded angled ends in the rear corners so does not fit that well) but rather that the hood is either too low in back (look at the fit at the cowl) Too far back, has been sprung from lifting it too high, the stops are unscrewed or the car has been hit in the front and slightly shortened!
The factory hood seal is the best, Our reproduction has the molded corners and fits very well, and I think that Mark makes a nice fitting one as well I see a lot of 914's with front trunk lids that sit just a little bit high, especially around the headlights. This is also an issue on my new 914. PO claims the problem is due to a poor fitting (aftermarket) weather strip. I want to correct this on my car. Which parts vendor has the best fitting front trunk weather strip? I am told tha 914rubber is very good quality? Any tips for removal of the old and installation of the new is much appreciated. Thanks! |
NJ914Guy |
Jan 15 2011, 10:19 AM
Thanks for the tips Doc. I will check the adjustment points before I order parts. If all looks good, would removing the stripping and checking fit be a good test to rule out a poor fit issue?
Mikey914 |
Jan 16 2011, 12:41 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Kind of funny, I made a front trunk seal but it did actually hold the front trunk up too high. That's why I never released it (the neoprene version).
I will be retooling for it in the future, but have a few other items on my plate right now. I did notice the composition of the OEM seal had molded corners that do put pressure to hold it up slightly. So, some pressure is to be expected, and yes there is some adjustment, but not a lot. The big problem with most of the seals on the market is that they use foam rubber (yes even the one I'm currently doing does), and the foam holds water like a sponge.This is best reason for not gluing it down. |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:32 AM |
