Gearbox, Both tailshift and sideshift |
Niklas |
Jan 21 2011, 01:40 PM
Porsche 914 Sweden Group: Members Posts: 366 Joined: 20-June 09 From: Sweden - Skivarp Member No.: 10,488 Region Association: Scandinavia |
Hello!
My gearbox looks like it is both sideshift and tailshift in the same gearbox. It is now working as a sideshift but the tailshiftparts are still there. How is it possible and what gearbox is that ?? Niklas |
SirAndy |
Jan 21 2011, 01:43 PM
Resident German Group: Admin Posts: 41,681 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
How is it possible and what gearbox is that ?? You can convert a tailshift to a sideshift. My guess would be someone tried to do just that ... (IMG:style_emoticons/default/shades.gif) |
pcar916 |
Jan 21 2011, 01:49 PM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
How is it possible and what gearbox is that ?? Niklas Both tailpieces fit on the side shift version. But it can't be both internally. When the tailshift rear cover is installed on a sideshift box there are some holes that have to be plugged, or they can be used to extract oil to a cooler... or to install a temperature probe. In the latter case I'd rather collect temp from somewhere closer to the R&P. (IMG:style_emoticons/default/beerchug.gif) |
Bruce Hinds |
Jan 21 2011, 10:04 PM
V-8 madness Group: Members Posts: 733 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
I wouldn't be surprised if it was a sideshift and someone broke the tail cone by the mounting ear and replaced it with a tail shift cone.
Dave_Darling |
Jan 22 2011, 04:43 PM
When the tailshift rear cover is installed on a sideshift box there are some holes that have to be plugged... One easy way to plug the largest hole in the tailshift tail cover, when used on a side-shift transmission, is to leave the shift selector in it. My guess is that either this is a converted transmission, or a side-shifter that broke a tail cover and had it replaced. Which of the gear selector bits is hooked up? --DD |
Lo-Fi Version | Time is now: 10th June 2024 - 11:40 PM |
