Removing pivot shaft and bushings from rear trailing arm, Tech advice |
hotlanta914 |
Jan 23 2011, 05:21 PM
Newbie Group: Members Posts: 21 Joined: 15-July 06 From: Atlanta, GA Member No.: 6,438 |
What is the best way to remove bushings and pivot shaft? Is it worth the effort and what would you suggest for replacement-Delrin, rubber, poly-graphite? (IMG:style_emoticons/default/welder.gif)
nsyr |
Jan 23 2011, 05:28 PM
Because I Can Group: Members Posts: 314 Joined: 16-May 04 From: Tampa, FL Member No.: 2,073 |
if this is a street car and your existing bushings are in decent shape then leave it as is. there have been plenty of discussions here, just use the search to find them.
hotlanta914 |
Jan 23 2011, 05:51 PM
Thanks - the bushings are in decent condition. I wanted to remove the bushings and shaft so that I can take the trailing arms to powder coat. I have not bee able to find any discussion on this yet. Thanks for your help.
Cheapsnake |
Jan 23 2011, 05:54 PM
Member Group: Members Posts: 419 Joined: 15-November 07 From: Door County, WI Member No.: 8,341 |
You're in for a treat. Not a real hard job, just gets a little messy. The shaft simply drives out with a BFH. Make sure you protect the threads with a nut or use a lead hammer.
The bushings have become one with the TA and come out with heat. Run a torch over the outside of the bushing housing and once the bushings soften up they'll slide right out. DO THIS OUTSIDE! because as soon as the bushings heat up they'll smoke like crazy and you don't want any part of it. I used polycarbonate bushings. if you use them make sure you hone them for a snug (not tight) fit and install grease zerts or they'll squeak. Good luck. Tom |
hotlanta914 |
Jan 23 2011, 10:14 PM
You're in for a treat. Not a real hard job, just gets a little messy. The shaft simply drives out with a BFH. Make sure you protect the threads with a nut or use a lead hammer. The bushings have become one with the TA and come out with heat. Run a torch over the outside of the bushing housing and once the bushings soften up they'll slide right out. DO THIS OUTSIDE! because as soon as the bushings heat up they'll smoke like crazy and you don't want any part of it. I used polycarbonate bushings. if you use them make sure you hone them for a snug (not tight) fit and install grease zerts or they'll squeak. Good luck. Tom Thank you for your help Tom. This is my second 914 build. I didn't tackle this challenge last time, but I have learned that every 914 repair is an adventure in creative problem solving. Brian |
tradisrad |
Jan 23 2011, 10:50 PM
Senior Member Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
I used a three jaw puller and pressed the shaft out. I first tired heat and drilling the rubber, but the puller worked the best. http://www.914world.com/bbs2/index.php?sho...c=98630&hl=
914werke |
Jan 24 2011, 12:39 AM
"I got blisters on me fingers" Group: Members Posts: 10,145 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
I disagree, dont use a torch, either find a buddy, a local shop or get yerself a issue of SI or Car & driver look in the back for a 20% coupon to HF and PU an shop press for the cost of what that shop will charge you to press them out!
Lo-Fi Version | Time is now: 11th June 2024 - 06:55 AM |
