Carb Conversion, Replacing Distributor for Carb conversion |
falconfp2001 |
Feb 2 2011, 04:14 PM
Pancho Pantera Group: Members Posts: 451 Joined: 5-December 10 From: Downey, CA Member No.: 12,456 Region Association: Southwest Region |
Quick question, for carb conversion, is the 009 Bosch the recommended Distributor?
Isn't there two versions of that Distributor? Thanks Frank |
Bleyseng |
Feb 2 2011, 04:26 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
use the stock distributor as it has the right advance curve. The 009 is a piece of shit with the wrong advance curve. (IMG:style_emoticons/default/chair.gif)
gothspeed |
Feb 3 2011, 04:06 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
I like this one for its simplicity and vacuum advance (IMG:style_emoticons/default/smile.gif)
http://www.hot-spark.com/Hot-Spark-SVDA034-3BOS4U1.htm |
falconfp2001 |
Feb 3 2011, 06:33 PM
Has anyone had experience with this? It is mainly advertised for type 1 installations but I think this could be a good replacement system.
any thoughts? DIS4-009 DISTRIBUTORLESS IGNITION SYSTEM |
SLITS |
Feb 3 2011, 06:52 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
No experience, but I have one in a box that I have never used. It's still based on the 009 distributor, but it acts only as a trigger for the coils.
You can put the guts in a standard distributor from what I was told and that would give you the correct advance curve. The other option is to use a 1.8 distributor. No FI trigger points and a good advance curve for the carbs. |
gothspeed |
Feb 3 2011, 08:51 PM
The 'centrifugal advance' portion of the 034 is advertised to be equal to a 'properly setup' 009, except the vacuum advance gives you better 'off idle' throttle response and depending on which vacuum source you tap from, also get better fuel economy.
There are lots of ignition articles with varying clarity, here are a couple of them; http://www.gofastforless.com/ignition/advance.htm http://www.lbfun.com/warehouse/tech_info/t...m_explained.pdf The 034 I linked to, is PRE-setup and includes electronic points, so once you set the timing....... it should be very low if any maintainence at all ..... (IMG:style_emoticons/default/smile.gif) ......... your time setting will depend on your compression/engine mods. .... oh and I bought their coil to make sure I am within their warranty. |
dlo914 |
Feb 4 2011, 11:47 AM
Whatchu' lookin' at?!?! Group: Members Posts: 3,432 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 |
Anything about replacing the cam, i recall hearing in the past that the EFI cam isn't the proper gearing (wrong term maybe) for carbs. But then i could of heard wrong.
gothspeed |
Feb 4 2011, 05:46 PM
Anything about replacing the cam, i recall hearing in the past that the EFI cam isn't the proper gearing (wrong term maybe) for carbs. But then i could of heard wrong. Yeah I also heard the stock cam will not benefit from going to carbs. It supposedly even loses power, driveability and definitely fuel economy with carbs. |
sean_v8_914 |
Feb 5 2011, 01:12 PM
Chingon 601 Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 |
I would recommend the stock L jet or D jet dizzy over the unknown advance curve ofthtis "034" aftermarket dizzy. I have never used one but pondered about what it might be good for. has anyone here ever used one?
I like bleysing's answer....tell us how you really feel. the stock cam is fair to "OK" with small carbs. it will get you going but not the optimum choice |
gothspeed |
Feb 5 2011, 06:52 PM
Here is more info on vw distributors;
http://vw.zenseeker.net/Ignition-Distributor.htm the 034 is a factory bosch design that came on air cooled flat fours, the 'aftermarket' 034 version has had the advance curve 'dialed in' by the selling company for carb applications. The 009 is more for WOT/racing and not good for daily driving, as the 009 cannot adjust the curve for load/part throttle the way a vacuum dizz can. The 009 will have an 'off idle' flat spot, among other undesireable effects in daily/city driving. My engine should be on the dyno in the next month or so ....... then in the car a couple months after that ...... I will then be able to give 'first hand' feedback on it. Do not buy any dizz based my posts, it was just what I decided to buy for my modded 2056cc, based on my own research and feedback from vw people I trust. So to be safe, one can always use the factory dizz that came on the engine. |
VaccaRabite |
Feb 5 2011, 08:06 PM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Replacing the cam on a t4 will do a lot for you with carbs. BUT.
Replacing the cam means that you have to split open the case. And that means a lot of work. Once the case is opened and you have the new cam, new cam bearings, etc, you may as well rebuild the entire motor. After all, its all open there. And after redoing all that work (including new pushrod geometry since you changed the cam) you may as well make sure that your heads are good, etc. etc. Zach |
falconfp2001 |
Feb 9 2011, 10:08 PM
Change of tactics and another question?
I decided to make the Carb Conversion a build on a 2.0 long Block core that I'm trying to acquire. So for the mean time, I'm going to swap my old and failing 1.7 with one that I purchased in good condition with FI intact. Question, what is the preferred replacement Dizzy for the 050 if I can't reuse my old 050? I think I read that there are differences between FI dizzy and Carb Dizzy? thanks for any input. Frank |
nsr-jamie |
Feb 10 2011, 03:41 AM
914 guy in Japan Group: Members Posts: 1,182 Joined: 7-November 07 From: Nagoya, Japan Member No.: 8,305 Region Association: None |
Tangerine Racing sells a nice one too, I plan on getting that someday soon when funds allow.
mrdkrantz |
Feb 10 2011, 07:11 AM
Newbie Group: Members Posts: 35 Joined: 28-December 10 From: Eastern Shore MD Member No.: 12,532 Region Association: North East States |
The difference in the dis from carb to FI is the advances when you give the car throttle. i would reuse your old FI dis and not upgrade until you get your 2.0 done. -save your money
For your 2.0 see Mr. Chris at Tangerine Racing. He sells the Mallory dis and he will even set it up for your engine with the correct advance. -I wish I would have instead i bought mine online and had to pick his brain for help on here and 914club |
hot_shoe914 |
Feb 10 2011, 07:12 AM
on ramp passer Group: Members Posts: 3,802 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
The 050 is a good dizzy for dual carbs from what I have heard. (IMG:style_emoticons/default/confused24.gif)
eg914 |
Feb 11 2011, 12:15 AM
Member Group: Members Posts: 319 Joined: 17-June 04 From: Elk Grove, CA Member No.: 2,223 Region Association: None |
Has anyone used an 031 mechanical advance dizzy with carbs? I believe they were for the 912. I have one that I used in a Squareback years ago, and it seemed to drive well.
Lo-Fi Version | Time is now: 2nd June 2024 - 12:26 PM |
