70 1.7 rear axle nut, size mm |
914 shifter |
Feb 5 2011, 09:25 PM
airhead Group: Members Posts: 266 Joined: 28-August 10 From: ny/nj Member No.: 12,111 Region Association: North East States |
does anyone know what size 6 point socket i need for this nut? (the one just outside the rear rotor) i have a 1 1/4 in but its a little to big, and its frozen solid. (IMG:style_emoticons/default/hissyfit.gif) or should i say rear hub
rohar |
Feb 5 2011, 09:53 PM
Senior Member Group: Members Posts: 924 Joined: 25-October 08 From: spokane Member No.: 9,685 Region Association: None |
30mm. You're probably gonna need a $15 braker bar from ACE and about a 6' piece of pipe to brake it loose. Don't be afraid to jump on it.
914 shifter |
Feb 5 2011, 09:59 PM
30mm. You're probably gonna need a $15 braker bar from ACE and about a 6' piece of pipe to brake it loose. Don't be afraid to jump on it. thank you,i have a breaker bar, and 4' pipe just need that 30mm.i also have pb blaster, and map torch on standby (IMG:style_emoticons/default/ar15.gif) (IMG:style_emoticons/default/cheer.gif) |
rohar |
Feb 5 2011, 10:04 PM
Soak it in PB blaster now. It'll help tomorrow when you try and pry it off.
/I hate that nut //not as bad as pushing out the stub axles though |
914 shifter |
Feb 5 2011, 10:19 PM
rohar |
Feb 5 2011, 10:29 PM
If you do a search, you'll find innumerable posts on replacing the rear bearings. There's about 20 ways to pull the rear axle apart. All of them seem to involve a lot of cursing and heavy objects.
I like to blare Alice and Chains "Angry Chair" when I have to do it. Don't know why, but it seems fitting. |
Andyrew |
Feb 6 2011, 12:03 AM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
First time is the hardest. After that you can remove and reinstall it easily. I keep a spare CV with me and keep the locking pin off, I can remove and reinstall a CV on the side of the road in ~ 25 mins with this method.. But that first time is a bitch..
draganc |
Feb 6 2011, 09:53 PM
Senior Member Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
Soak it in PB blaster now. It'll help tomorrow when you try and pry it off. /I hate that nut //not as bad as pushing out the stub axles though that's affirmative been soaking since about 6pm EST.hopefully i can locate a 30mm sunday morning. thanks again rohar if you are not in a hurry let it soak for several days. i did both sides about 4-5 months ago and what a FPITA! after the 3rd day soaking i got one nut off. pb blast penetrated only half the nut. for the left side i had to use the grinder and a new nut. good luck, dragan ps: make sure your wear gloves and make sure your kids are not around.....bad words |
Lo-Fi Version | Time is now: 6th June 2024 - 04:28 AM |
