Can anyone tell me how to remove trim |
thesey914 |
Apr 12 2003, 08:16 AM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
I'm trying to remove these two pieces so I can strip the car ready for painting.
The Chrome trim on the rear of the targa bar attaches/unattaches how? And how does the coat hook unfasten so I can remove the inside sail panel trim? Cheers -J.Seymour |
Gint |
Apr 12 2003, 08:20 AM
Mike Ginter Group: Admin Posts: 16,082 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Dunno about the coat hook. The chrome roll bar trim is removed by first removing the two down pieces on the side. On those, one screw is on the outside as you can see. The other is a nut on the backside of the trim at the bottom. You will have to go up underneath the rear quarter. Then the cross piece "pops" off. It has clips that use spring tension on the back side of the trim piece.
That's all the time I have for now. I could possibly get some pics for you later. I have to go pull a motor/trans now. |
JeffBowlsby |
Apr 12 2003, 08:26 AM
914 Wiring Harnesses Group: Members Posts: 8,526 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
The coat hook is a plastic cover that slips over and snaps to a metal bracket, which is fastened with a screw. Carefully pry off the cover cap and its a no brainer.
thesey914 |
Apr 12 2003, 08:53 AM
WOW, Cheers Guy's.....that was almost instantaneous!! Ginter...I (eventually) managed to work out the nut for the curved trim piece (buried beneath inches of mud) but was worried about forcing the cross piece.
Jeff -thanks for the coat hook info. -J.Seymour |
Lo-Fi Version | Time is now: 2nd June 2024 - 06:14 PM |
