Daytime LEDs, Not sure if i like it. |
7TPorsh |
Mar 10 2011, 11:06 AM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
Had a brain fart at Pep Boys and bought a couple led strips. I want to increas my visibility. Car is driven mostly daytime.
After playing with a few options I decided to put them in the horn grills. Luckily they squeeze in perfectly between the vanes and can be clipped every 3rd light. Powered with an inline fuse and to the ignition side of the fuse box so they go on with the key. bot the 12" and trimmed 3 lights. They are a lot brighter in person. Camera battery was running down but managed a few pics. I'm changing the bulbs in my H4s to match. Night pics soon I hope. |
7TPorsh |
7TPorsh |
Mar 10 2011, 11:07 AM
7TPorsh |
Mar 10 2011, 11:08 AM
flipb |
Mar 10 2011, 11:10 AM
Senior Member Group: Members Posts: 1,728 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region |
I like it. Did you cut the horn grills or are these mounted in between slats?
If they're pretty bright (for use as DRLs), I think it's a very useful and cool looking mod. |
pt_700 |
Mar 10 2011, 11:11 AM
Senior Member Group: Members Posts: 1,094 Joined: 4-March 10 From: san jose, ca Member No.: 11,430 Region Association: Northern California |
kind of on the fence but, think i'd prefer the usual round lights there, wired to be on during the day if increased visibility is what you're after.
kind of a "me too!" look, following audi. just my 2 cents. |
736conver |
Mar 10 2011, 11:13 AM
Advanced Member Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None |
If you want to increase your visibility paint your car orange. (IMG:style_emoticons/default/biggrin.gif)
7TPorsh |
I like it. Did you cut the horn grills or are these mounted in between slats? If they're pretty bright (for use as DRLs), I think it's a very useful and cool looking mod. Fit perfect between the slats. Visible in the daytime and bright at night. i can tell because at stoplights I can see eyeballs across the intersection wandering to my car where before it wasn't as much. |
tradisrad |
Mar 10 2011, 11:14 AM
Senior Member Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
I like the idea, but why not install some fog lamps and run with them on?
I checked out your build thread. Looks like you put the fuchs and center consol in your '70, but kept the seats in the early configuration. I did the same with mine and I consider the fuchs and center consol a tasteful upgrade. Nice job. I also put the corvette brake light on my engine lid to help folks see that I am stopping... |
7TPorsh |
If you want to increase your visibility paint your car orange. (IMG:style_emoticons/default/biggrin.gif) Thought of that awhile ago...tangerine is my favorite...but kept the original color after the crew chimed in. (IMG:style_emoticons/default/piratenanner.gif) |
7TPorsh |
Mar 10 2011, 11:17 AM
Thought of fog lights but then I would need new grills and lights and expense goes up. This was $20.
Wanted to modernize a little. I think with all these new roadsters companies are making, our 914s can actually look like a current design. |
7TPorsh |
Mar 10 2011, 11:19 AM
I like the idea, but why not install some fog lamps and run with them on? I checked out your build thread. Looks like you put the fuchs and center consol in your '70, but kept the seats in the early configuration. I did the same with mine and I consider the fuchs and center consol a tasteful upgrade. Nice job. I also put the corvette brake light on my engine lid to help folks see that I am stopping... Thanks...need to work on the rear next. These strip led are really bright behind the rear lenses. Have to think of something there. |
Eric_Shea |
Mar 10 2011, 11:36 AM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
There's two camps. I'm not in that camp but, it looks good and looks to be very well done. (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/wink.gif)
BKLA |
Mar 10 2011, 12:12 PM
Really old member Group: Members Posts: 1,253 Joined: 14-August 05 From: OR Member No.: 4,590 Region Association: Pacific Northwest |
Tried something similar - where I wrapped the fog light hole with a circle of LED's... wasn't thrilled with the look. (personal opinion)
On a highly modified car, they look good IMHO. But not a "stock" looking teener.... |
7TPorsh |
Mar 10 2011, 12:17 PM
Beginning to think I should pull them off and toss them back on the rice-roni shelf.
As I see your comments come in I'm thinking it may cheapen the look of the car. |
7TPorsh |
Mar 10 2011, 12:18 PM
As I'm looking at these pics...are the side mirrors supposed to droop down like this?
SGB |
Mar 10 2011, 12:25 PM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
I like 'em more here than on an Audi. Pretty hip.
2 points- Fogs on without HLs will get you a ticket here in my little town. Even as "markers". BTDT. That left HL cover can be re-aligned. Loosen up the three allen head bolts on the pivot part toward the inside of the trunk. Take out the "eyebrow" in front of the light assembly- it just is held by rubber bumps protruding into holes. Align the headlight in closed position to try to follow hood surface, tighten down. You may have to fiddle with the other (fender) side pivot, or loosen and move the motor just a little. More visibility is alwaysa a good thing (unless you are Charlie Sheen, I guess). |
ConeDodger |
Mar 10 2011, 12:26 PM
Apex killer! Group: Members Posts: 23,611 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
There's two camps. I'm not in that camp but, it looks good and looks to be very well done. (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/wink.gif) Eric is on the other side of the campground in a different tent but I agree... Looks to be well executed... But not what I would do. (IMG:style_emoticons/default/smile.gif) |
DanT |
Mar 10 2011, 12:35 PM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
turboman808 |
Mar 10 2011, 12:37 PM
Advanced Member Group: Members Posts: 2,718 Joined: 31-January 06 From: North Jersey Member No.: 5,505 Region Association: North East States |
Rice O Roni shelf sounds like a good place for it.
I am seeing these more and more on riced out pieces of shit. Hopefully that means Audi will stop doing it. Always thought it looked stupid and it hurts my eyes even during the day. |
Lo-Fi Version | Time is now: 7th June 2024 - 09:06 PM |
