Inner Long Replacement in Hell Hole, Could use some advice on how to weld it to front section |
saigon71 |
Mar 13 2011, 06:14 PM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
I have been following quite a few of the build threads related to this subject, but I am still a little confused about how this replacement panel gets attached at the front. Do you butt weld it with a sleeve? It looks as though it will "wrap" around the section running back from below the door...do you lap weld it and sleeve it? I left the section running back from the door a little long so I can trim it after I figure out how this thing goes together. Hopefully the attached pics help to explain the situation.
two-strokejohn |
Mar 13 2011, 07:32 PM
Member Group: Members Posts: 81 Joined: 30-March 06 From: Orient, Ohio Member No.: 5,793 Region Association: North East States |
Check out Jeff Hail's repairs at this http://www.914world.com/bbs2/index.php?sho...hl=rust++repair then go to page 7, post 134. It appears that buttwelded it , and then puts a double reinforcement panel inside of it to strengthen the area and to provide a solid base for the seat belt anchor.
IronHillRestorations |
Mar 13 2011, 10:13 PM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Yes, you butt the joints flush and everything will line up better, then put a plate on the blind side. I've also put a bulkhead inside that long, up in the suspension console area.
Lo-Fi Version | Time is now: 11th June 2024 - 11:49 PM |
