won't start, will start..... |
mipstien |
Apr 13 2011, 07:47 AM
Member Group: Members Posts: 261 Joined: 6-April 10 From: Maryville, TN Member No.: 11,576 Region Association: South East States |
Weird problem started about 3 days ago. in the mornings, around 9:30am i go to start my car and it doesn't start. weather has been 50-60 with no humidity 3 days ago then yesterday it was cold and raining and today about 50 with a lot of humidity.
when i get home around 3:30pm it starts fine. its obviously a lot hotter. although yesterday it was still very cold and raining. my 5th injector isn't plugged up right now cause i don't have the temperature control plug connected so it has no ground. anyways, this morning i got it running by putting a tiny tiny bit of gas in one of the vacuum lines. less than a teaspoon probably. it may not have even been the gas that time it may just have been i let it sit for approx 5 minutes and it decided to run. my fuel pump is working fine and i put gas in it yesterday so its about half a tank. it has started up in its parking spot fine all winter long. its turning over fine and it seems to be getting fuel. the only thing i haven't checked is the spark. i can't say that its getting fuel and spark at this point cause i don't know 100% with either of these. i was more wondering if anyone else has a won't start in the morning but starts after the day heats up type of thing? |
TheCabinetmaker |
Apr 13 2011, 08:02 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
If everything is working properly, it should start every time regardless of temp or humidity. I would look at the AAR valve. The cold start valve doesn't kick in till about 35 degrees F.
Bartlett 914 |
Apr 13 2011, 08:27 AM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
This is where a fuel pressure gauge comes in handy. You cannot really tell if you have pressure without one. I had the same problem. My relay board would sometimes not let the fuel pump run. With the gauge installed in the engine compartment, I could immediately see that the problem was fuel and I went from there. Installing a gauge is cheap and easy. Here is a thread on this subject.
Fuel pressure gauge |
Lo-Fi Version | Time is now: 6th June 2024 - 08:13 PM |
