Replacing the trans mounts, 911 sport's |
Trekkor |
May 10 2004, 08:23 AM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
Hey, hey!
I'll try to replace the mounts this week. Any suggestions on supporting the 914 and trans to slip in these little gems? Will the trans ( supported by floor jack ) after removing mount bolts, lower down enough to install. Waiting for the voice of experience on this. (IMG:style_emoticons/default/clap56.gif) |
Rusty |
May 10 2004, 10:48 AM
Wanted: Engine case GA003709 Group: Admin Posts: 7,941 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch |
Yep... lowering it down should be enough. Be sure to disconnect (and then reconnect) the grounding strap on the left side of the transmission.
-Rusty (IMG:style_emoticons/default/smoke.gif) |
Dave_Darling |
May 10 2004, 12:02 PM
914 Idiot Group: Members Posts: 14,990 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I would also loosen, but not remove, the nuts on the bottom of the rubbber motor mounts. Best not to bend them too much. (Guess how I know this?? Could it have anything to do with me leaving the transmission on a floor jack, which sagged down overnight? Naaaaahhh...)
--DD |
Trekkor |
May 12 2004, 09:00 PM
Thanks guys . Got it done in about an hour.
I didn't loosen the motor mounts. I did remove the ground strap and lowered the trans just about 6 inches. No problems. Now to road test. (IMG:style_emoticons/default/MDB2.gif) |
Trekkor |
May 12 2004, 10:32 PM
What a difference!
If your shifter vibrates or shakes in 3rd gear or higher esp when coasting while in gear, these mounts will solve your problem. Also getting into 1st gear is much easier now (IMG:style_emoticons/default/clap56.gif) |
Brad Roberts |
May 12 2004, 10:36 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
The 914 mounts are EXPENSIVE. This is a nice alternative and works VERY well.
B |
Red-Beard |
May 13 2004, 07:49 AM
"Ya canna change the laws of Physics" Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None |
The "trick" is pushing the bolts up before you start jacking the back backup. As everything aligns, the bolts slip down into place.
Lo-Fi Version | Time is now: 23rd May 2024 - 04:02 AM |
