skline |
Born to Drive ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California ![]() |
Took the yellow car for a putt around the town today. I must say, it is pretty impressive. 2270 has more power than I thought it would. The thing just gets it at any RPM. The low end torque is really strong. The carbs make a lot of noise too and it sounds great. I now remember why I like these cars so much. What a ride!
seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
Jeff Bonanno |
il dottore ![]() ![]() Group: Members Posts: 421 Joined: 30-April 03 From: San Diego, CA Member No.: 636 ![]() |
(IMG:style_emoticons/default/agree.gif) on both points - did you build the 2270? add it to your sig!
swood |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None ![]() |
That one had the straight cut gears? What components for the build did you use again?
skline |
Well, I would add it to my sig but its not mine anymore. I built it with a 78mm crank and 96mm pistons and cylinders. Rimco did all the machine work on it and yes it has straight cut gears in it with a SCAT cam and lifters. I dont remember off hand what the lift and duration was but it was a little higher than a Web cam 86b. The flywheel is lightened and the pistons were all balanced within .05 grams. Rimco balanced the entire rotating assembly before I put the engine togther. The thing is very impressive when you accelerate at any RPM. The carbs really have a throaty sound to them and it just gets up and goes. Being yellow its not really the car you go buzzing through traffic in town with as it stands out especially with all the noise. But it breaks the tires loose when you just punch it after you start rolling and when you hit second and nail it too. By that time you are up around 55 or 60 and being in town, that is too fast. I will miss this car when its gone. I take it in tomorrow for a leak down test to verify everything is good on it. Once that is done, the guys are coming to get it and take it away. So I am driving it in the mean time since it is still fully insured and the reg is still in my name. I might as well enjoy it while its here. Tons of fun.
bernbomb914 |
one of the oldest Farts on this board ![]() ![]() ![]() Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 ![]() ![]() |
sounds like fun to me. when I fix my trans my2270 will go in. can hardly wait
yellow is faster Bernie |
Lo-Fi Version | Time is now: 17th June 2024 - 03:50 AM |
