Smog Test, Can't pass cruise CO |
jaminM3 |
Apr 20 2011, 12:02 PM
Member Group: Members Posts: 418 Joined: 23-March 07 From: SLC, UT Member No.: 7,619 Region Association: Intermountain Region |
I have searched the forum and I can't find any info on getting your car to pass the smog test?
I have a '74 with a 2.0. It passed in fall of '09 and I drove it to RRC. The only thing I have done since then is relocate the gas pump to the front. This has successfully stopped the vapor locking issue. Does somebody out there now what I need to do to adjust the FI? It passes the idle test fine but the cruising test fails for Carbon Monoxide. You can smell it too. I think it is running pretty rich. (IMG:style_emoticons/default/confused24.gif) |
r_towle |
Apr 20 2011, 12:14 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
could be a bad or failing mps, an TPS adjustment issue, or a CHT issue.
It can also be your cold start may be stuck open, that also happens. Check here for the tests on the TPS, CHT and MPS http://members.rennlist.com/pbanders/DjetParts.htm |
r_towle |
Apr 20 2011, 12:15 PM
Also, do the simple stuff first.
Tuneup, new points, plugs, cap and rotor. Set valve adjustment Set dwell Set timing. In that order... Rich |
Andyrew |
Apr 20 2011, 12:38 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Do you have the printout you can scan? Or tell us the numbers? This way we know how far off you are.
championgt1 |
Apr 20 2011, 12:41 PM
Don't embarrass me Filmore! Group: Members Posts: 2,680 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest |
Damn, I'm glad I don't have to do this.
Mike Bellis |
Apr 20 2011, 12:47 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
If you buy a 1976 914 here you face this same crap.
Mine is exempt from testing! (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) |
Drums66 |
Apr 20 2011, 02:06 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
Damn, I'm glad I don't have to do this. I hear you! (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/smoke.gif) (IMG:style_emoticons/default/bye1.gif) |
Eric_Shea |
Apr 20 2011, 02:36 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Standard UT BS.
Mine are registered at my "SUMMER HOME" (cough-cough) in Heber. |
76-914 |
Apr 20 2011, 03:34 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
IIRC, there was member here who had quite an extensive thread related to smoking in AZ. I think the member was Armyowalgreens???
Rand |
Apr 20 2011, 03:43 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Standard UT BS. Mine are registered at my "SUMMER HOME" (cough-cough) in Heber. Eric, does the registration address not have to match the one on your driver's license? I was smog exempt in Seattle, but here in Reno it has to be smogged every year. (IMG:style_emoticons/default/headbang.gif) I thought about using my friend's address in Gardnerville to get around it, but wasn't sure that would fly with a Reno address on my license. I thought they checked that. I don't know how it works everywhere, but here a classic or historic registration and plate takes you out of the system... Get past smog once, get the status, then done. |
jaminM3 |
Apr 20 2011, 04:04 PM
It says the CO% standard is 5%, mine tested 7.36% and 10.4% last fall when I tried it the first time. I brought it to a local mechanic to install the 911 front suspension and brakes and had him look at the tune. That is why it went down.
It passed the year before and I only drove it like a thousand miles. You can smell it, there is something wrong with the tune. |
r_towle |
Apr 20 2011, 04:13 PM
valve adjustment
dwell timing |
Dave_Darling |
Apr 20 2011, 09:20 PM
Fuel pressure, CHT resistance, vacuum leaks (esp fuel injector seals, MPS hose, manifold), MPS failing...
Look through the articles on Brad Anders' website (link in Towlie's first reply). --DD |
moparrob |
Apr 20 2011, 09:27 PM
Senior Member Group: Members Posts: 646 Joined: 27-April 10 From: Los Angeles Member No.: 11,663 Region Association: None |
Long live Webers... (IMG:style_emoticons/default/poke.gif)
ArtechnikA |
Apr 21 2011, 10:24 AM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
It says the CO% standard is 5%, mine tested 7.36% and 10.4% last fall Are you running premium gas? Stop. run the lowest octane that will prevent detonation, at least for the duration of the test. Higher octane == more resistance to burning. unburned fuel == high CO. |
Drums66 |
Apr 21 2011, 11:31 AM
valve adjustment dwell timing ....Also get her good & hot....before testing (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/bye1.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 01:21 AM |
