| Dr Evil |
Apr 24 2011, 07:50 PM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
I initially was doing this to show to my clinic participants, but I figure that everyone can benefit from this information. I was doing this on Kansas914's gear box and just happened to find that his input shaft bearing was no more (see pics).
Step one can be done in two ways. I choose to use a tapered punch and place it in a bolt hole with the tip pressing against a rib. The 19mm bolt in the flange should not be torqued very much so this is not an issue. If the drift starts to bend significantly, switch to method #2. Method #2 is to put two bolts in the flange and use a bar of some sort, down low on the flange surface, against the bolts. ![]() Once the 19mm bolt is removed you just pull the flange out. Remove all the cover bolts and tap the cover at the arrowed locations to remove it. ![]() |
| Dr Evil |
Apr 24 2011, 07:55 PM
Once the cover is removed you can now inspect the pinion (money shot). If the pinion shows wear that is not too big of a deal. It is a problem if your pinion is galled (gouged).
The camera made this one look worse than it is. If you can feel the streaks, it is gonna howl and wear out even more and faster. The remnants of the input shaft bearing is pointed out. This is better to find now before more damage is done. ![]() |
| Dr Evil |
Apr 24 2011, 07:56 PM
Here is where the bearing parts should be.
| montoya 73 2.0 |
Apr 24 2011, 08:03 PM
Lack of consideration to others, and Selfish! ![]() ![]() ![]() Group: Members Posts: 1,791 Joined: 27-October 04 From: Paso Robles, Ca. Member No.: 3,016 Region Association: Central California |
That looks familiar. I believe mine was broken in half and had to be replaced at the clinic. Luckily it stayed in place.
| scotty b |
Apr 24 2011, 08:05 PM
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
glad you made it home (IMG:style_emoticons/default/beerchug.gif)
| Kansas 914 |
Apr 25 2011, 06:51 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,006 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains
Holy Crap! The car sat for 15 years - then I cranked it up and drove it around the block in 2003. Clutch was frozen - or so I thought - so I started it in gear - then hit the gas and it broke free - well I guess something did - but the clutch worked after that though it slipped like a bitch.
So what is your professional prognosis? Thanks Mike! |
| jimkelly |
Apr 25 2011, 07:51 AM
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
so that bearing is optional -sweet : )
| hot_shoe914 |
Apr 25 2011, 07:57 AM
on ramp passer ![]() ![]() ![]() ![]() Group: Members Posts: 3,807 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
Did you have doubts dude? (IMG:style_emoticons/default/WTF.gif) He was driving my car. My cars go everywhere and always reach their destination. (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/slap.gif) (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/slap.gif) (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/slap.gif) (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/slap.gif) (IMG:style_emoticons/default/poke.gif) |
| Dr Evil |
Apr 25 2011, 07:59 AM
Mike, I'll talk with you for options. I have replacements, no biggie. I am on 24hr OB call today, though...
| Kansas 914 |
Apr 25 2011, 08:03 AM
| zymurgist |
Apr 25 2011, 08:22 AM
"Ace" Mechanic ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
Did you have doubts dude? (IMG:style_emoticons/default/WTF.gif) He was driving my car. My cars go everywhere and always reach their destination. (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/slap.gif) (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/slap.gif) (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/slap.gif) (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/slap.gif) (IMG:style_emoticons/default/poke.gif) Because you own a tow dolly? |
| warrenoliver |
Apr 25 2011, 09:39 AM
Member ![]() ![]() Group: Members Posts: 363 Joined: 11-November 06 From: McFarland, Wisconsin Member No.: 7,199 Region Association: Upper MidWest |
[/quote] (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) |
| KELTY360 |
Apr 25 2011, 09:43 AM
914 Neferati ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,170 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest
[quote name='warrenoliver' date='Apr 25 2011, 08:39 AM' post='1466235']
I am on 24hr OB call today, though... [/quote] (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) [/quote] Better watch what you ask for.....you just might get it. (IMG:style_emoticons/default/shades.gif) |
| Root_Werks |
May 5 2011, 10:27 AM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,853 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
PNW Tranny Clinic is only a couple days away. This is a good thread to read. |
Lo-Fi Version | Time is now: 2nd December 2025 - 01:10 AM |
