Help Identifying Pictures, From 74 1.8 L-Jet Engine Compartment |
Levi |
May 22 2004, 04:02 PM
Lick my nuts Group: Benefactors Posts: 623 Joined: 11-March 04 Member No.: 1,783 |
I'm chasing Vacuum lines and checking, fixing and replacing them, as I do I'm running across things that don't look quite right some of which I'm unable to Identify, Any help you can give is appreciated...
Can you tell me what this is, Does, it was bolted to the bottom of the Battery box. does it need to be grounded. Attached image(s) |
Levi |
May 22 2004, 04:05 PM
This piece is just laying in the engine compartment it looks like it was screwed to something and looks like it should be Grounded??????
Attached image(s) |
ejm |
May 22 2004, 04:09 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,693 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
Thats the resistor pack for the fuel injectors..
no need to ground it but it would be better screwed down. Second pic is the dual relay for the FI... same advice |
SirAndy |
May 22 2004, 04:11 PM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
amazing ...
914 parts i have never seen before! i'd say, if you don't need smog, take it all off and sell it on ebay! Andy |
skline |
May 22 2004, 04:12 PM
Born to Drive Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California |
Those are both parts for the FI, The one on the battery box should be bolted there, and the other one just bolt it anywhere taht is close to where you found it. I dont think the one needs to be grounded but I am not sure. I would bolt them both down in anycase.
SirAndy |
May 22 2004, 04:13 PM
QUOTE(ejm @ May 22 2004, 03:09 PM) Thats the resistor pack for the fuel injectors.. no need to ground it but it would be better screwed down. Second pic is the dual relay for the FI... same advice interesting. i assume this is L-Jet then, right? |
Levi |
May 22 2004, 05:05 PM
QUOTE(SirAndy @ May 22 2004, 02:13 PM) QUOTE(ejm @ May 22 2004, 03:09 PM) Thats the resistor pack for the fuel injectors.. no need to ground it but it would be better screwed down. Second pic is the dual relay for the FI... same advice interesting. i assume this is L-Jet then, right? Yup.... (IMG:style_emoticons/default/wink.gif) "Help Identifying Pictures," "From 74 1.8 L-Jet Engine Compartment" (IMG:style_emoticons/default/beerchug.gif) |
SirAndy |
May 22 2004, 05:11 PM
QUOTE(Levi @ May 22 2004, 04:05 PM) Yup.... (IMG:style_emoticons/default/wink.gif) "Help Identifying Pictures," "From 74 1.8 L-Jet Engine Compartment" guess i could just have read it! (IMG:style_emoticons/default/biggrin.gif) can't help you much there, don't know anything about L-Jet. my 1.8 was already converted to D-Jet when i got it. much less parts to worry about. (IMG:style_emoticons/default/wink.gif) Andy |
Mark Henry |
May 22 2004, 05:12 PM
Both should be screwed to the battery tray support.
Mueller |
May 22 2004, 05:16 PM
Andy,
I took this from the Megasquirt site...gives a little info on why the resistors: QUOTE Pulse Width Modulation Injectors are either high impedance or low impedance. High impedance injectors (usually about 12-16 ohms) can take a 12 supply directly, without a form of current control. Low impedance injectors (generally below 3 ohms) require some form of current limiting. With MegaSquirt, you can use resistors to limit current, or you can use Pulse Width Modulation (PWM), which is a software solution built in to MegaSquirt. Levi, It's a good idea to become familiar with these parts, helps troubleshooting down the road. The dual relay item: with key on, flapper opened (manually or by the vacum of the engine), this d/r gets energized, when it does, it powers the injectors (injectors fire when grounded by the ECU) it also turns on the fuel pump...this is good to know, if having problems or testing the fuel system, you can simply turn on the ignition, and open the flapper box, now you should have fuel pressure..(as long as dual relay is working properly) |
Levi |
May 22 2004, 07:09 PM
Thanks a million guys!!!!!
Its back together now and Still runs like Shit (IMG:style_emoticons/default/sad.gif) |
Lo-Fi Version | Time is now: 6th June 2024 - 06:26 AM |
