Pressing in 100mm wheel studs, How to keep them straight? |
Phoenix-MN |
Jun 8 2011, 07:52 PM
Senior Member Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
(IMG:style_emoticons/default/confused24.gif) So, I'm installing 100mm wheel studs on my front 911 hubs to use with spacers. Stock ones press out easily and I start to press in the 100mm ones. After I get 3 pressed in the spacer still slides on and fits. After installing the 4th it starts to bind just a bit. After pressing in the 5th stud, the spacer will no longer slide on . They don't press in exactly perpendicular to the hub face and the spacer will not slide over the studs now. For those who have actually done this what's the trick in getting these pressed in straight?
Thanks Paul |
SirAndy |
Jun 8 2011, 08:07 PM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
For those who have actually done this what's the trick in getting these pressed in straight? They will straighten out the first time you torque them down. If you can't get the spacer on right now, put it over one stud at the time and use a open end steel lug-nut to torque each one down. That will seat the stud correctly and they should work fine after that. The holes, backside of the hub around the holes and and the lower part of the stud have to be perfectly clean! Any dirt will prevent the stud from seating correctly ... (IMG:style_emoticons/default/smash.gif) |
rick 918-S |
Jun 8 2011, 08:09 PM
Hey nice rack! -Celette Group: Members Posts: 20,485 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I didn't have the luxury of having a 911 front end. I drilled my hubs on my drill press. I used a drift to install the 100mm studs and used my spacer to align them. Even the wheels are a little snug to the holes but not an issue. I have thousands of road miles on mine.
Randal |
Jun 8 2011, 08:11 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
For those who have actually done this what's the trick in getting these pressed in straight? They will straighten out the first time you torque them down. If you can't get the spacer on right now, put it over one stud at the time and use a open end steel lug-nut to torque each one down. That will seat the stud correctly and they should work fine after that. The holes, backside of the hub around the holes and and the lower part of the stud have to be perfectly clean! Any dirt will prevent the stud from seating correctly ... (IMG:style_emoticons/default/smash.gif) I second what Andy said. I used a big torque gun on mine and lots of washers to get them to seat. |
Phoenix-MN |
Jun 9 2011, 09:19 AM
For those who have actually done this what's the trick in getting these pressed in straight? They will straighten out the first time you torque them down. If you can't get the spacer on right now, put it over one stud at the time and use a open end steel lug-nut to torque each one down. That will seat the stud correctly and they should work fine after that. The holes, backside of the hub around the holes and and the lower part of the stud have to be perfectly clean! Any dirt will prevent the stud from seating correctly ... (IMG:style_emoticons/default/smash.gif) Thanks Sir, seating each one did the trick (IMG:style_emoticons/default/piratenanner.gif) Paul |
jaxdream |
Jun 9 2011, 09:39 AM
Senior Member Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
I made a fixture to use on my press ( I am fortunate to own one ) to press studs into and out of front or rear hubs .Works great as I robbed studs from a set of 928 hubs ( 78 mm ) to press into my 5 lug conversion hubs .
Lo-Fi Version | Time is now: 6th June 2024 - 07:51 PM |
