So, I'm installing 100mm wheel studs on my front 911 hubs to use with spacers. Stock ones press out easily and I start to press in the 100mm ones. After I get 3 pressed in the spacer still slides on and fits. After installing the 4th it starts to bind just a bit. After pressing in the 5th stud, the spacer will no longer slide on . They don't press in exactly perpendicular to the hub face and the spacer will not slide over the studs now. For those who have actually done this what's the trick in getting these pressed in straight?
Thanks
Paul
