Pressing in 100mm wheel studs, How to keep them straight? |
Phoenix-MN |
Jun 8 2011, 07:52 PM
Senior Member Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
(IMG:style_emoticons/default/confused24.gif) So, I'm installing 100mm wheel studs on my front 911 hubs to use with spacers. Stock ones press out easily and I start to press in the 100mm ones. After I get 3 pressed in the spacer still slides on and fits. After installing the 4th it starts to bind just a bit. After pressing in the 5th stud, the spacer will no longer slide on . They don't press in exactly perpendicular to the hub face and the spacer will not slide over the studs now. For those who have actually done this what's the trick in getting these pressed in straight?
Thanks Paul |
Lo-Fi Version | Time is now: 17th May 2024 - 05:59 AM |
