scrz914 |
Member ![]() ![]() Group: Members Posts: 422 Joined: 21-April 04 From: Santa Cruz, CA Member No.: 1,960 Region Association: Central California ![]() |
I know that gas starts to degrade after sitting for 6 months. My car hasn't run for about a year now. My plan was to drain the fuel out, but it looks like there's more in the tank than I thought and I don't have a big enough pan.
Would 12 month old gas damage the injectors? Could I mix in some fresh gas and get away with running the old through? Anyone with have this experience? |
tod914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 ![]() |
If it's not E10 gas, and you used Stabil or the like, you should be ok. Peek inside the tank and see if it smells like varnish or if there is rust in the tank. If it's E10 gas, drain it. It starts to go bad after 3 months. Get a couple of plastic fuel cans to empty it into. You'll just need something to pinch/plug the lines. Not too bad. Had to do it 2x this year due to crap gas.
tod914 |
And change your fuel filter while your at it.
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,196 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
If your engine and fuel system are stock, I think your chances are pretty good. My car started right up after sitting for several years.
Highly-tuned race engines, on the other hand, can have very severe problems on race gas that is only a few months old. --DD |
underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
Don't worry about it on an injected car. Carbs would be another story.
scrz914 |
Gas still smells normal. I feel better about just mixing in some fresher gas.
I havne't heard of the term E10 gas. Ethanol maybe? Thanks for the responses. |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Start it, drive it, get rid of the fuel....fill with super and a bottle of Tektron FI cleaner and have a great season.
Rich |
scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
If it is ethanol GET IT OUT !!! I have a 930 and my motorcycle in my shop both with ethanol issues, The 930 sat for a little over a year, and my bike sat for all of 5 months. I took my carbs apart and all of the brass was coverd in green growth. I had previously JUST rebuilt them and the bike was running great. F*ck ethanol (IMG:style_emoticons/default/dry.gif)
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
Yeah, E10 is shorthand for the sorry excuse for gas that we have to deal with these days.
I think there are still a few places that have the real stuff, but we've been stuck with this stuff for years in Chicagoland. It seems to cause the most problems when it's first introduced into an area where the old cars have been running straight gasoline for years, now all sorts of stuff starts dissolving with then newly introduced ethanol. Let's just hope that they don't start making the E15 that is being proposed. It would be one thing if it reduced the dependency on foreign oil (kind of a patriotic thing), but it takes more energy to procude the ethanol than is saved by its use as a motor fuel! Just my 2 cents. |
sean_v8_914 |
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 ![]() |
get rid of it.
dont run it CA gas, right? what's your engine worth? |
carr914 |
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 125,886 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States ![]() ![]() |
e10 is bad before it even goes in your Tank (IMG:style_emoticons/default/barf.gif)
914rat |
Member ![]() ![]() Group: Members Posts: 279 Joined: 3-July 06 From: Maryland Member No.: 6,362 ![]() |
E10 caused me a total top end teardown and gummed up my valves.The machine shop I took it to said that E10 is hell on NA flat tappet carbed engines.Use stabilizer even if it's sitting for a few weeks.
Drums66 |
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region ![]() |
......I agree just dump it!!! (IMG:style_emoticons/default/idea.gif)
(be safe!) (IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif) |
scrz914 |
Turns out to be a moot point..fuel pump no longer circulates gas. It could be that sitting for that long has caused internal problems. I'll have to pull it and when I do I'll do the long awaited tank restoration as well.
Has anyone resurrected one of these pumps by soaking it in diesel? |
Lo-Fi Version | Time is now: 4th July 2025 - 10:58 AM |
