Differences btwn 914 and 914-6 transaxles?, the tail shifters |
Cairo94507 |
Jun 18 2011, 09:47 AM
Michael Group: Members Posts: 9,826 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
OK, I know the 914-6 came with a 914/01 transaxle that was of course a tail-shifter. I know the 4 cylinder cars came with a tail-shifter too, but not a 914/01.
What was the difference between the two other than the serial number? I have a non-six transaxle in my car and I believe I want to find an original six transaxle for my car and then have it rebuilt with the proper gearing for a 3.2 street driven car. I also want to upgrade to a nice shifter system to make driving more enjoyable. JWest shifter? I already know their shift linkage assemblies are no longer available. Should I then have the six transaxle converted to a side shifter? Should I just use all stock six shifting hardware, rods, etc. with the exception of the shifter assemble itself? Should it remain a tail shifter or would I be better served to convert to a side shifter? (I would keep the original tail shifter stuff just in case). I really don't have a clue but know that I want to do this right the first time and not regret spending $XXXX and then changing to a completely different system later. Thanks for any advice, suggestions and/or personal experience. Michael (IMG:style_emoticons/default/popcorn[1].gif) |
sixnotfour |
Jun 18 2011, 11:15 AM
914 Wizard Group: Members Posts: 10,436 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
QUOTE What was the difference between the two other than the serial number? gearing and the tail cover. Dont sweat the 914/01 it wont be Origonal anway. QUOTE I be better served to convert to a side shifter? (I would keep the original tail shifter stuff just in case). Go for it. QUOTE Thanks for any advice, suggestions and/or personal experience. ticktockticktock 50 plus better get on it. I am in the same boat. Jeff |
toolguy |
Jun 18 2011, 11:24 AM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
Acording to the factory shop manuals, 914-4 has A- F- -N- V- ZD gears while a six came with A- GA- O- V- ZA
larryM |
Jun 18 2011, 12:20 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
BTDT - it is simpler to just go buy a sideshifter
& don't worry about the gear ratios - you will just lose about 3-5 mph on the straight at Thunderhill by running a late sideshift - and I never could get over 100 there anyway, so it was irrelevant - you will need to also get the entire late shifter, rods, etc, and a adaptor bush for the firewall, (i have 2 sets if ya need one) AND - importantly - a special-made aft shift rod - GPR used to make & sell these, and I have had one in my car since it started racing in the early 90's; worst case - I successfully bent & twisted a stock late style aft rod a long time ago to make it fit around the exhaust, and I still have it in the shed - no work of art, but it worked regarding the oem sixer tailshifter - I had a lot of trouble with the puny lever that goes up into the trans - it ain't a very strong component, and more than once i found myself under the car manually shifting into 3rd so I could limp it home back in the '8o's LarryM OK, I know the 914-6 came with a 914/01 transaxle that was of course a tail-shifter. I know the 4 cylinder cars came with a tail-shifter too, but not a 914/01. What was the difference between the two other than the serial number? I have a non-six transaxle in my car and I believe I want to find an original six transaxle for my car and then have it rebuilt with the proper gearing for a 3.2 street driven car. I also want to upgrade to a nice shifter system to make driving more enjoyable. JWest shifter? I already know their shift linkage assemblies are no longer available. Should I then have the six transaxle converted to a side shifter? Should I just use all stock six shifting hardware, rods, etc. with the exception of the shifter assemble itself? Should it remain a tail shifter or would I be better served to convert to a side shifter? (I would keep the original tail shifter stuff just in case). I really don't have a clue but know that I want to do this right the first time and not regret spending $XXXX and then changing to a completely different system later. Thanks for any advice, suggestions and/or personal experience. Michael :popcorn: |
Cairo94507 |
Jun 19 2011, 09:52 AM
IronHillRestorations |
Jun 19 2011, 10:25 AM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Yea the 6 has a lower 5th gear, which translates to higher cooling fan speeds for the 2.0 6. I had a stock 4 cyl side shifter with my 3.0 and (for me anyway) the gearing was perfect.
I make conversion shift rods for 6 conversions, but it's not rocket scienct. There is a bend and angle to it that makes a difference from just a straight bar that some people have sold, and FWIW I made a bunch of shift rods for Dave at GPR back in the 90's. |
Cupomeat |
Jun 19 2011, 12:15 PM
missing my NY 914 in VA Group: Members Posts: 1,336 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
If you can get/borrow a copy of the Tramission rebuild video that Dr. Evil and I did, he shows the difference in the tail cone.
messix |
Jun 19 2011, 12:48 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
i think root werks built a jig to redo the side sifter bar. he's done some for people
sean_v8_914 |
Jun 19 2011, 12:55 PM
Chingon 601 Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 |
I agree with sixnotfour. you will regret keeping any remnants of tail shifter. I think a 3.2 would be hapier with taller -4 gearing
I would go side shifter with a jwest. the upgraded linkage joints have no play makes for nice positive shifting feel |
dion9146 |
Jun 20 2011, 05:16 AM
Member Group: Members Posts: 469 Joined: 16-May 04 From: Buckner, KY Member No.: 2,071 Region Association: MidAtlantic Region |
I'm running a stock 4 side suffer with a 3.2 and have no complaints at all. I only use 1st gear on a hill, and for street gearing I think it's fine.
FWIW, if you get the right shift rod, bushings, and a well built tranny, your car should shift fine. I have zero complaints about how my car shifts, and for me anyway, upgrading to a $500+ shifter is a waste of money. |
jimkelly |
Jun 20 2011, 06:27 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
diff cover?
Attached image(s) |
sixnotfour |
Jun 20 2011, 07:23 AM
you are correct Jim , however the 914-6 does not utilize the cable guide as do the 70-71 901 pull clutch cars do.
Lo-Fi Version | Time is now: 9th June 2024 - 02:04 PM |
