Advise?, Distributor failure |
ILM914 |
Jul 6 2011, 06:50 PM
Member Group: Members Posts: 96 Joined: 3-March 09 From: NC Member No.: 10,126 Region Association: None |
Hi All; Anyone have their Dizzy wear out? What are the symptoms? My car seeems to run poorly and on a couple of cylinders. it hesitates and bucks when I drive it. And when I push the distributor to the side while it is running the engine runs better. I suspect the dizzy shaft bearings. I have checked and or replaced everything else that I thought it might be previously. Anyone use Cardone replacement dizzy, or Malory? Are they good/reliable? Thank you for the help, Happy motoring, Joe
simonr |
Jul 6 2011, 07:18 PM
Member Group: Members Posts: 65 Joined: 11-July 10 From: Indianapolis Indiana Member No.: 11,925 Region Association: None |
Make sure your distributor is being held tight by the clamp. If it moves around your timing will be off. A worn distributor will cause any number of driving discomforts. remove the distributor make sure the cam lobe is lubed with bosch cam grease. check the play on the shaft. verify your timing when put back in. Ed Fall in Sandy Utah is the best at rebuilding distributors and ensuring the advance curve
stugray |
Jul 6 2011, 07:33 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
we had this exact failure at the last Vintage racing event.
An MG was missing on two cylinders, and everything checked out fine when the engine wasnt running. Turns out the dizzy bearings were bad and the rotor was wearing out the dist cap contacts very quickly. Symptoms were just as you describe. Stu |
914Mels |
Jul 6 2011, 09:09 PM
Member Group: Members Posts: 357 Joined: 20-June 11 From: Santee Member No.: 13,221 Region Association: Southern California |
Hi All; Anyone have their Dizzy wear out? What are the symptoms? My car seeems to run poorly and on a couple of cylinders. it hesitates and bucks when I drive it. And when I push the distributor to the side while it is running the engine runs better. I suspect the dizzy shaft bearings. I have checked and or replaced everything else that I thought it might be previously. Anyone use Cardone replacement dizzy, or Malory? Are they good/reliable? Thank you for the help, Happy motoring, Joe I wonder if you have a bad connection or broken wire at your trigger points? Possibly when you are moving the distributor, you are making a good connection on the connector or wire. If one side isn't working, you'll lose two cylinders. try to wiggle just the connector and see if that helps. |
ILM914 |
Jul 8 2011, 03:16 PM
I had tought it was the 3 prog connection on the back of the distributor until i realized what i was doing when i manipulated to plug was torqing the dizzy which made it run a little better until I let go of it. Thank you I'm sure the Dissy needs replacing or rebuild. This has been a good lesson in diagnostics for me. Thanks everyone, Joe
simonr |
Jul 8 2011, 03:31 PM
Check out Ed Fall on the Samba. 150.00 He will make it like brand new.
ILM914 |
Jul 23 2011, 10:54 AM
Thank you, the guy that sold me a bad Dizzy now won't return my calls to return it will post his info if he doesn't take it back.
r distri Y Hi All; Anyone have their Dizzy wear out? What are the symptoms? My car seeems to run poorly and on a couple of cylinders. it hesitates and bucks when I drive it. And when I push the distributor to the side while it is running the engine runs better. I suspect the dizzy shaft bearings. I have checked and or replaced everything else that I thought it might be previously. Anyone use Cardone replacement dizzy, or Malory? Are they good/reliable? Thank you for the help, Happy motoring, Joe |
ILM914 |
Jul 30 2011, 03:05 PM
Thanks everyone, yest the Dizzy had a stuck mechanical advance inside the unit, had it unstuck by a local shop, car is running awesone.
Thank you, the guy that sold me a bad Dizzy now won't return my calls to return it will post his info if he doesn't take it back. r distri Y Hi All; Anyone have their Dizzy wear out? What are the symptoms? My car seeems to run poorly and on a couple of cylinders. it hesitates and bucks when I drive it. And when I push the distributor to the side while it is running the engine runs better. I suspect the dizzy shaft bearings. I have checked and or replaced everything else that I thought it might be previously. Anyone use Cardone replacement dizzy, or Malory? Are they good/reliable? Thank you for the help, Happy motoring, Joe |
Lo-Fi Version | Time is now: 31st May 2024 - 11:24 PM |
