QUOTE(ILM914 @ Jul 6 2011, 05:50 PM)
Hi All; Anyone have their Dizzy wear out? What are the symptoms? My car seeems to run poorly and on a couple of cylinders. it hesitates and bucks when I drive it. And when I push the distributor to the side while it is running the engine runs better. I suspect the dizzy shaft bearings. I have checked and or replaced everything else that I thought it might be previously. Anyone use Cardone replacement dizzy, or Malory? Are they good/reliable? Thank you for the help, Happy motoring, Joe
I wonder if you have a bad connection or broken wire at your trigger points? Possibly when you are moving the distributor, you are making a good connection on the connector or wire. If one side isn't working, you'll lose two cylinders. try to wiggle just the connector and see if that helps.
