FS:1973 1.7L 914 $1800.00 Price Reduced Greenwood , IN |
rettigdw914 |
Jul 9 2011, 03:57 PM
Newbie Group: Members Posts: 16 Joined: 17-September 04 From: Greenwood, IN Member No.: 2,774 |
Guys, I am letting my car go, wife wants it out of the house and no more funding is available. Here is the post:
Up for sale is a 1973 Porsche 914 with a 1.7L engine. This car still has fuel injection and has not been replaced with carbs. The following is a list of items replaced/fixed: -All Push Rod tube seals replaced - Valves adjusted -Points have been changed over to compufire electronic ignition -New spark plugs and wires added 6 months ago - Compression test on all 4 cylinders about a year and a half ago was 120 psi with no more than 4 psi variability between cylinders. -Rebuilt fuel pump(30psi solid), -Injectors ultrasonically cleaned -Rebuilt MPS from Bret Instruments -TPS calibrated -Vacuum lines replaced, -Injector seals replaced -Intake runner gaskets and hose to plenum replaced -Rebuilt distributor -New cap,rotor,coil Purchase also includes lots of extra parts, used set on Koni rear struts, a good parts transmisstion, the full factory service manual electronically searchable(over 1000 pages), and much more information on these cars. Items needing to be fixed/improved: - It has low power under load and my mechanic said he is 70% sure it needs a new clutch as it appears to be slipping. Clutch kits are $350.00 - Second gear syncro is worn but it does shift - needs new door handles - crack in windshield - need new engine cover brackets and may need new trunk lid. - some rust on the passenger quarter panel and on the longtitutinals. If you check out the price for a fully restored car, they can go for much more. I simply don't have the time anymore and the wife wants it gone. These are fun cars to drive and they have amazing cornering. Price is $1800.00, cash only and I cannot deliver. I have title on hand. No scams please Due to the clutch issue, it is driveable for about 10 miles, longer than that, I would recommend a trailer, unless you know how to drive a car with a slipping clutch as I do not. Attached thumbnail(s) Attached image(s) |
rettigdw914 |
Jul 10 2011, 01:55 PM
By the way, any PMs on what you think it is worth are welcome as well.
Ky914Newbie |
Jul 11 2011, 07:26 AM
Newbie Group: Members Posts: 14 Joined: 17-January 11 From: Kentucky Member No.: 12,604 Region Association: South East States |
I would like to see pics of the rust on the longs and hell hole to get a better idea of what a restoration would take.
rnellums |
Jul 11 2011, 08:59 PM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
I also would be interested in some Pictures of the rusty areas. I am located in Lafayette as well.
rnellums |
Jul 11 2011, 09:39 PM
I may actually be able to come see it Friday afternoon if you are available after 5.
rettigdw914 |
Aug 5 2011, 05:00 PM
My apologies for the late reply, I was counting on getting an e-mail when someone responded to my post. If you are still interested feel free to e-mail me at dwrettig@sbcglobal.net or call me at 317-460-7049.
I am reposting this ad tonight with a price reduction to $1800.00 I have added some pics to the initial post above. I'll try to get some pics of the Longs. When it was in the shop, I asked the mechanic to check out the longtitutinal under the battery tray. He said it is still solid even though there is some rust. Thanks, Don |
rettigdw914 |
Aug 5 2011, 06:26 PM
Here are pics of the longtitudinal on the passenger side. The hose is for the Air conditioning.
Thanks, Don Attached thumbnail(s) |
Lo-Fi Version | Time is now: 1st June 2024 - 02:33 AM |
