CV Question, Removal for bearing replacement |
rjames |
Jul 13 2011, 05:45 PM
I'm made of metal Group: Members Posts: 3,955 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
I am trying to replacing the rear wheel bearings. I am at the point where I have the inboard CV bolts removed and have removed the big castelated nut. Not sure what to do now. Should CV and axle be removable at this point? Right not it's not moving much at all.
I also have read posts of people who have removed the CV's only to have the the CV 'balls' fall out. Sounds not-so-fun. How do I avoid that, or is there only danger of that happening if I take apart the individual pieces of the CV itself? After I have the CV removed, should I rebuild the CV as a 'While I'm in there?' I have done an extensive search on the site and read many a thread, but am still stuck and don't see an easy explanation in the Haynes manual. Thanks! |
ArtechnikA |
Jul 13 2011, 05:57 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
I am trying to replacing the rear wheel bearings. I am at the point where I have the inboard CV bolts removed and have removed the big castelated nut. Not sure what to do now. Should CV and axle be removable at this point? Yes. Put some good penetrating oil on the exposed end of the stub axle and let it sit. Put the big nut back on - inverted - so that its big flat section is exactly flush with the end of the styb axle. Using a big brass hammer, tap the end of the nut. That should pursuade it back through the hub. This is the good method, and it helps if the person before you used a good anti-sieze compound on the splines. Try this first. If it doesn't budge after really smacking it, there are other paths you can escalate to. (Read the recent thread from the guy who got hit up for a new stub axle because his shop screwed it up getting it out - to the tune of about $600...) QUOTE I also have read posts of people who have removed the CV's only to have the the CV 'balls' fall out. Sounds not-so-fun. How do I avoid that Keep everything in line. The balls can only fall out if the joint is angled more than normal. |
rwilner |
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
I am sure others will chime in, but my two cents:
You have done the hard part. Remove the entire half shaft by remove the 4 cv bolts at the flange. Then you can bang the stb axle out. On e the half shafts are out why not refresh the cv joints? How long has it been? Easy to do -- disassemble, clean , grease, new boots, washers, bolts, cv gaskets. There is an awesome 2 part step by step on YouTube on exactly how to do this for 914 cv joints -- a quick search and it should pop right up. |
SLITS |
Jul 13 2011, 05:58 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
When you say "inner bolts" I hope you are talking about the ones that hold the CV to the transmission output flange.
Once the CV is loose from the transmission, you can raise it over the tranny (maybe have to remove the starter) and it should slide out of the hub. If it seems stuck, thread the castle nut back on the stub axle and hit it with a brass hammer to see it it frees up ... regular hammer works to, but you don't want to screw up the nut or threads by pounding on them. The CV joints will move on the beam. Don't push them back towards the center of the beam or you will lose your balls. Lot easier with the engine out of the car. |
SLITS |
Jul 13 2011, 05:59 PM
double post damnit!
MoveQik |
Jul 13 2011, 06:08 PM
What size wheels can I fit? Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
The CV joints will move on the beam. Don't push them back towards the center of the beam or you will lose your balls. So that's what happened. One side I heard the soothing sounds of each ball hitting the concrete. All the while wondering, "Hmm...I wonder how that goes back together." (IMG:style_emoticons/default/dry.gif) |
SLITS |
Jul 13 2011, 06:12 PM
The CV joints will move on the beam. Don't push them back towards the center of the beam or you will lose your balls. So that's what happened. One side I heard the soothing sounds of each ball hitting the concrete. All the while wondering, "Hmm...I wonder how that goes back together." (IMG:style_emoticons/default/dry.gif) Uh Mike, you lost your .......... Nevermind! |
stugray |
Jul 13 2011, 06:18 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Be careful it IS possible to get the CV back together backwards and the it doesnt work right. It is like a cool puzzle. Look for darkened ball-bearings or scarred surfaces once you get them cleaned up. Stu |
rwilner |
Jul 14 2011, 11:10 AM
sixnotfour |
Jul 14 2011, 11:36 AM
914 Wizard Group: Members Posts: 10,436 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Robert, I can remove the rear wheel bearings without removing the axles.
Let me know I can run over popem out and reinstall the new ones WITH the axles and stubs in place. I am in Edmonds so its no problem. Jeff I never like removing the axles, so I tooled up so I would never ever have to agian, Its great when doing 5 lug conversions. |
Cap'n Krusty |
Jul 14 2011, 11:55 AM
Robert, I can remove the rear wheel bearings without removing the axles. Let me know I can run over popem out and reinstall the new ones WITH the axles and stubs in place. I am in Edmonds so its no problem. Jeff I never like removing the axles, so I tooled up so I would never ever have to agian, Its great when doing 5 lug conversions. I would be interested in hearing exactly that's done. Maybe my imagination is worn out, but I can't picture how it could be done. The Cap'n |
sixnotfour |
Jul 15 2011, 01:00 PM
I'll take pictures, worth a thousand words
sixnotfour |
SLITS |
Jul 15 2011, 01:59 PM
Robert, I can remove the rear wheel bearings without removing the axles. Let me know I can run over popem out and reinstall the new ones WITH the axles and stubs in place. I am in Edmonds so its no problem. Jeff I never like removing the axles, so I tooled up so I would never ever have to agian, Its great when doing 5 lug conversions. I would be interested in hearing exactly that's done. Maybe my imagination is worn out, but I can't picture how it could be done. The Cap'n My imagination/guess..... Make a tool to pull the hub ... inner race of bearing will probably come with it. With that slop, you could then drive out the outer race. It's having the small hands & wrench to get the bearing retainer fasteners out that get me. (IMG:style_emoticons/default/biggrin.gif) |
SLITS |
PeeGreen 914 |
Jul 15 2011, 04:11 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
Cap'n Krusty |
Jul 15 2011, 04:13 PM
You've jumped to a wrong conclusion, He's posting for both of MY personalities. The Cap'ns |
ArtechnikA |
Jul 15 2011, 04:25 PM
Roses are red;
Violets are blue; I'm not schizophrenic; And neither am I. |
sixnotfour |
Jul 15 2011, 04:38 PM
Slide hammer hub off
remove bearing retainer 4 bolts push back stub (small amount) insert tool tighten tool slide hammer bearing out install new bearing, special tool not made yet,so hammer with aluminum on outer race. install retainer (4bolts) put hub up to bearing. thread special tool onto stub tighten to draw hub into bearnig remove tool install washer and nut and tighten the F out of it. |
ArtechnikA |
Jul 15 2011, 05:39 PM
Sounds a lot like the tool someone had made for the Rabbit/Audi front wheel bearings. I almost bought one, when I was getting about 6 weeks life per bearing, but I couldda bought 3 presses for the price, and I only needed one. By that time I was stocking spare hubs and just prefitting them with bearings so if I had a failure at an event I could just change the upright.
I can't recall who made that tool. Baum, maybe. Techtonics Tuning sold them. |
Lo-Fi Version | Time is now: 10th June 2024 - 05:07 AM |
