Doors cannot be opened from outside of car, broken nylon outer door handle lock inserts |
davesporsche1 |
Jul 18 2011, 11:45 AM
Newbie Group: Members Posts: 3 Joined: 3-January 11 From: Lake Havasu City, AZ Member No.: 12,560 Region Association: None |
The doors on my 914 are closed and the windows are up. The nylon outer door handle lock inserts are broken and the doors cannot be opened from the outside. Does anyone have any ideas how I may get a door opened so that I can repair the door handle without breaking a window? I know from past experience that the doors can be opened from inside the car. (IMG:style_emoticons/default/confused24.gif)
r_towle |
Jul 18 2011, 12:01 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
two coat hangers twisted together.
Put a loop on the end. You are aiming for the opposite side inner door handle. It takes time, but it can be done. Go in via the top back corner of the window, up high. Rich |
davesporsche1 |
Jul 18 2011, 12:22 PM
two coat hangers twisted together. Put a loop on the end. You are aiming for the opposite side inner door handle. It takes time, but it can be done. Go in via the top back corner of the window, up high. Rich Thanks Rich. I'll give it a try. (IMG:style_emoticons/default/smile.gif) |
Mikey914 |
Jul 18 2011, 12:32 PM
The rubber man Group: Members Posts: 12,679 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Been there done that.
Can be done, just a pain. |
Jeffs9146 |
Jul 18 2011, 12:35 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
I have also had some luck with releasing the rear roof latches with a coat hanger! Then you can pick up the back of the roof and slide something long in (broom handle?) and release the front ones!
avidfanjpl |
Jul 18 2011, 02:42 PM
914 Hemophiliac Group: Members Posts: 720 Joined: 6-April 10 From: Bear, Delaware Member No.: 11,566 Region Association: MidAtlantic Region |
Done both the rear targa locks and the door locks. With the right steel 5 foot long rod with a hook on it, the door is easier.
Once you get the targa locks off, you still have a better time going for the door. Front targa locks are impossible. I got the driver door lock tab in 1 minute not so long ago. John |
KELTY360 |
Jul 18 2011, 03:01 PM
914 Neferati Group: Members Posts: 5,037 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
two coat hangers twisted together. Put a loop on the end. You are aiming for the opposite side inner door handle. It takes time, but it can be done. Go in via the top back corner of the window, up high. Rich (IMG:style_emoticons/default/agree.gif) I had to do this at the 1st IROC run at Riverside Raceway (R.I.P) with my brand new '73 1.7. Because the race was run with identical 911 RSRs the lot was filled with Porsche owners and everybody who passed by while I was working the coat hangers would try their keys in the lock. I finally got it open with the hangers but it took a lot of patience. |
andys |
Jul 18 2011, 03:39 PM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
(IMG:style_emoticons/default/agree.gif) I had to do this at the 1st IROC run at Riverside Raceway (R.I.P) with my brand new '73 1.7. Because the race was run with identical 911 RSRs the lot was filled with Porsche owners and everybody who passed by while I was working the coat hangers would try their keys in the lock. I finally got it open with the hangers but it took a lot of patience. I too was at the first IROC at RIR; that was in '73 huh? What was the feature race? CanAm maybe? Lot's of fond memories of that place! Andys |
URY914 |
Jul 18 2011, 03:46 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,106 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Take a sawzall and cut a hole in the roof. (IMG:style_emoticons/default/sawzall-smiley.gif)
davesporsche1 |
Jul 22 2011, 08:08 PM
thanks everyone! I was able to get in with some flat bar with a wire hook on the end. I was able to get the doors open without any damage. Eckler's sent the needed parts quickly and I was able to do the whole job, start to finish, including breaking into the car very quickly. As easy as it was to break into the 914, I'll be installing and alarm and LoJack before too many miles back on the road. (IMG:style_emoticons/default/biggrin.gif)
Thanks guys |
KELTY360 |
Jul 22 2011, 10:59 PM
(IMG:style_emoticons/default/agree.gif) I had to do this at the 1st IROC run at Riverside Raceway (R.I.P) with my brand new '73 1.7. Because the race was run with identical 911 RSRs the lot was filled with Porsche owners and everybody who passed by while I was working the coat hangers would try their keys in the lock. I finally got it open with the hangers but it took a lot of patience. I too was at the first IROC at RIR; that was in '73 huh? What was the feature race? CanAm maybe? Lot's of fond memories of that place! Andys Yes, CanAm was the feature. Mark Donohue dominated the IROC and then dominated with the Sunoco 917/30 in the CanAm race. |
Lo-Fi Version | Time is now: 15th June 2024 - 07:56 PM |
