Should the door latch be zinc? |
PanelBilly |
Jul 23 2011, 01:05 PM
914 Guru Group: Members Posts: 5,817 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Both the part on the body and the part on the door. Should they be zinc coated? The inside of the door assembly is zinc but the part you see isn't. Did it just wear off. And the unit that screws to the door jam that has the rubber on it. Should that be zinc?
tod914 |
Jul 23 2011, 04:49 PM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
Bill, the arm mechanism, the latches on both the door and door jam are a Clear Zinc. They look silvery. The unit with the rubber boot that screws into the door jam I seen 3 different ways.. can't verify if each part was "Factory" correct. The ones that are still availble are that dark yellowish zinc color. My 73 had black plastic with a different type of wiring set up. My current 74 has them in a clear zinc. The screws on the 74 are a dark yellowish zinc. Here's a link you can poke around in of the past cars. Should show the door jams in detail. http://s283.photobucket.com/albums/kk296/t...;cpZZ3QQtppZZ16
There's quite a few albulms.. the red car has a close up of that, and so does the white one. |
Lo-Fi Version | Time is now: 7th June 2024 - 02:15 PM |
