Squeal in engine, Mystery solved? |
jsaum |
Jul 24 2011, 08:10 PM
Senior Member Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
I finally got around to digging into the engine noise from last year after driving the car for less than an hour around the neighborhood I experienced a squeal in the engine, most noticeable when I let off of the gas. I drove it straight home less than five miles and parked it in the garage. I pulled the transmission out today and found the fly wheel bolts came loose. I torqued them down again and checked my end play and found the I'm out of tolerance by .002. I know I torqued them when I installed the fly wheel because I made a tool to hold the fly wheel, but I didn't check the end play.
I drained the engine oil and found brass fines in the oil, not a lot but some. I'm wondering if I have wiped out the bearings or if I stopped in time. Jsaum |
SLITS |
Jul 24 2011, 08:20 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Brass would be the distributor drive gear on the crankshaft getting eaten up as the crank moved fore and aft excessively.
jsaum |
Jul 24 2011, 08:51 PM
That's what I was wondering if I caught it in time do you think the engine can be saved by adding the correct shim?
Cap'n Krusty |
Jul 24 2011, 10:52 PM
That depends. If the play is in the shims, yes. If the play is the rear main thrust moving in the case, no.
The Cap'n |
Mark Henry |
Jul 24 2011, 11:00 PM
To add to the krusty one's post only if the end play can be made up with 3 shims, if you need 4 shims you're fuched. |
jsaum |
Jul 24 2011, 11:09 PM
(IMG:style_emoticons/default/agree.gif) To add to the krusty one's post only if the end play can be made up with 3 shims, if you need 4 shims you're fuched. Then I might be o.k! I measured and I need .002 shim to correct the end play. Jsaum |
rhodyguy |
Jul 25 2011, 07:33 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
i have a bunch of shims and the correct flywheel locking tool that makes the job much easier. let me know.
k |
Cap'n Krusty |
Jul 25 2011, 07:50 AM
.002 extra play isn't going to cause a squeal, IME.
The Cap'n |
rhodyguy |
Jul 25 2011, 08:14 AM
if the flywheel was loose could the TO bearing get uneven pressure? could that cause the noise?
jsaum |
Jul 25 2011, 09:32 AM
Drums66 |
Jul 25 2011, 11:54 AM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
.....Look to your distributor for your squeal? (IMG:style_emoticons/default/idea.gif)
(IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/popcorn[1].gif)( i agree with the 4 shims Fuched) |
Lo-Fi Version | Time is now: 7th June 2024 - 04:12 PM |
