FS 914GT Replica Roller SOLD!, Vintage Race Project full cage $5500 |
Twinplugflatsix |
Jul 28 2011, 01:56 PM
I'm new here ... Group: Members Posts: 0 Joined: 28-July 11 From: New England Member No.: 13,369 Region Association: North East States |
Hello all, here's my racecar project up for sale. Haven't gotten around to building my 914GT clone and now I could use the space and the money to invest in my new business. The initial work was done by Blackforest racing. I bought the tub but never got around to building it—too many projects.
email or PM me with questions/offers. Thanks, Jol 914@motomall.com Here is their description: This was intended to be the perfect vintage (HSR) 914 racer. This car up to this point has been built with time as no object - no corners have been cut, no amount of time has been spared. •1973 914 chassis •REAL OE Porsche GT flares. More then $2500 was spent in just purchasing and installing the flares. They are butt welded on - there are NO seams and NO remaining stock fender material underneath for a truely perfect fitment. •The roll cage is very nicely built, has a NASCAR style drivers door bar, and is well tied in to the proper places front and rear. •Chassis has OE Porsche GT siffening kit fully installed with some additional supports in key areas. •Custom oil cooler is fully fitted and installed in the front of the car. The cooler uses a 944 Turbo (951) intercooler core to emmulate the factory Porsche 935 cooling system. Has AN-12 fittings integrated. •GT style engine lid release handle has been fabricated and located in the engine grille area on the drivers side. •Windshield frame has 6 welded-in nut plates for windshield clips. •Patrick Racing 914-6 engine mount welded to chassis. Also included is the other half of this mount which bolts to the engine. •Front suspenion is 911S with Koni shocks. The chassis has been cut and drilled for a sway bar, and the mounting points are already on the A-arms. •Rear suspension uses Koni shocks and 200lb/in springs. The trailing arms have new bushings and the full GT stiffening kit installed. •All four wheels are 15" cookie cutters for rolling purposes. •Both doors have been extensively lightened. These doors are lighter the GT Racing composite door, and neither are flimsy in any way. Many hours were spent perfecting them. •Firewall is cut for access panel for belt changes and easy ignition timing adjustments. Female size of Dzus fastener is already installed and ready for a cover panel. •The car had been entirely stripped to bare metal and primered with basic grey primer. There is some surface rust forming through the grey primer, so we recently stripped the car completely back to bare metal and re-primed the car with a black self-etching rust inhibiting primer. Body work is 80% complete: It needs final sanding and a look over by a good painter before painting. A couple little rust spots on the firewall that will be super quick to fix—nothing even remotely structural. •Headlight doors have custom brackets that allow the headlights to be manually bolted in either the open or closed position. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.motomall.com-13369-1311882967.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.motomall.com-13369-1311882968.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.motomall.com-13369-1311882968.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.motomall.com-13369-1311882969.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.motomall.com-13369-1311882970.5.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.motomall.com-13369-1311882970.6.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.motomall.com-13369-1311882971.7.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.motomall.com-13369-1311882971.8.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.motomall.com-13369-1311882972.9.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.motomall.com-13369-1311882972.10.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.motomall.com-13369-1311882973.11.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.motomall.com-13369-1311882974.12.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.motomall.com-13369-1311882974.13.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.motomall.com-13369-1311882975.14.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.motomall.com-13369-1311882975.15.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.motomall.com-13369-1311882976.16.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.motomall.com-13369-1311882977.17.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.motomall.com-13369-1311882977.18.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.motomall.com-13369-1311882978.19.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.motomall.com-13369-1311882979.20.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.motomall.com-13369-1311882979.21.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.motomall.com-13369-1311882980.22.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.motomall.com-13369-1311882980.23.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.motomall.com-13369-1311882981.24.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.motomall.com-13369-1311882981.25.jpg) |
carr914 |
Jul 28 2011, 05:18 PM
Racer from Birth Group: Members Posts: 118,899 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
GLWTS - looks good & could go back to street with those Steel Flares (IMG:style_emoticons/default/biggrin.gif)
The Yellow Roller I have FS is also a BlackForest car - John has been around 914 racecars a long time and knows where to put his attention Well worth the money and the money difference between your car & mine is Steel vs FG Flares and your cage. T.C. |
Twinplugflatsix |
Jul 29 2011, 06:41 AM
T.C. Your car is definitely a bargain for someone who wants a street car.
I built my first 914 race car up from one that was on the street and over the years had to take it down to scratch to make it safe and reliable. This time I decided to start from a tub to save me from the inevitable reverse-direction work. Just don't have the time right now to do it. |
brant |
Jul 29 2011, 02:39 PM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
any pictures of the hell hole and longs?
Twinplugflatsix |
Aug 12 2011, 10:42 AM
Hell hole photo as requested.
I also have a complete donor car with bent tub. 2.5L twin plug, trick 901 w/quaife, 930 brakes, RSR Bilsteins, oil tank, fuel cell, instruments, etc. etc. enough to finish car. (IMG:http://www.914world.com/bbs2/uploads_offsite/motomall.com-13369-1313167346.1.jpg) |
hot_shoe914 |
Aug 12 2011, 10:30 PM
on ramp passer Group: Members Posts: 3,802 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
Twinplugflatsix |
Aug 15 2011, 11:26 AM
Sale Pending...
Twinplugflatsix |
Aug 21 2011, 05:14 PM
Sold, thank you all for your interest. I can’t wait to see the finished project.
carr914 |
Aug 21 2011, 06:31 PM
Sold, thank you all for your interest. I can’t wait to see the finished project. I also have a complete donor car with bent tub. 2.5L twin plug, trick 901 w/quaife, 930 brakes, RSR Bilsteins, oil tank, fuel cell, instruments, etc. etc. enough to finish car. (IMG:http://www.914world.com/bbs2/uploads_offsite/motomall.com-13369-1313167346.1.jpg) Congrats to Buyer & Seller - Did the Byer get the Donor car too? |
ecurie ecosse |
Aug 22 2011, 03:38 PM
I'm new here ... Group: Members Posts: 0 Joined: 22-August 11 From: Miami, FL Member No.: 13,478 Region Association: South East States |
^^ Yes, I bought both the tub and the donor car. (IMG:style_emoticons/default/smile.gif)
bcheney |
Aug 22 2011, 03:49 PM
Senior Member Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States |
That was a pretty good deal! All the best with this project...we need more 914's on the road and track in Florida!!
ecurie ecosse |
Aug 22 2011, 05:24 PM
^^ Thanks. I'm in MIA a good part of the year and the car will be here then. The (re)build will be done in NY and the finished product will be a dedicated track car. The plan is to take it HSR/SVRA racing.
carr914 |
Aug 22 2011, 05:27 PM
(IMG:style_emoticons/default/welcome.png) There are a few of us that do HSR/SVRA. Bullethead is down your direction |
ecurie ecosse |
Aug 22 2011, 06:18 PM
Danke.
Lo-Fi Version | Time is now: 1st June 2024 - 02:24 AM |
