73 1.7L djet to run off 73 2.0L djet components |
turnaround89 |
Aug 8 2011, 11:25 PM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
Would it be possible to get my 73 1.7L djet to run off of a 2.0L ecu, mps, and cht. I have all the proper parts for the 2.0L and have 1.7L injectors(yellow top). A lot of the other parts are interchangeable and i have those, i have a 5 pole TPS that should work after doing some reading here:
http://members.rennlist.com/pbanders/djetparts.htm I just want to make sure how to get everything connected and running properly. I have a decel valve from a 2.0L, is a 1.7L decel valve that much different that i will need a 1.7L decel valve or can i just run the 2.0L decel valve? Ive read that certain mps, cht, and ecu must be run together, and rennlist makes a note to say that a 73 2.0L ECU should only be used on a 2.0L, however, doing some reading here people say the ecu from 73 could be used on a 1.7L. How different are the ECU's from year to year? What type of vacuum hose diagram should i follow for this setup? any pics of a 73, i found the one from pelican but thats a 70, and does not show a decel valve. It almost seems like i would need to follow the 2.0L vacuum hose diagram. Any help would be great guys |
turnaround89 |
Aug 9 2011, 12:49 AM
Just read that i don't need to run the decel valve, just need to plug the lines. Ignore any questions about the decel valve.
orange914 |
Aug 9 2011, 09:31 AM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
73' ECU was used on BOTH the 1.7 and 2.0. There is a resister inline to the CHT for the 1.7.
edit: In rereading the post I'm not certain if your using a NON 73 ECU? |
turnaround89 |
Aug 9 2011, 10:48 AM
The ecu's that i have(i have three of them) are all the CU13x or part number: Bosch 0 280 000 037
The article makes note to only use the CU13x ecu with a 2.0L, and those are the only computers i have, is there anyway to get the car to run properly with this computer, or am i SOL? |
JeffBowlsby |
Aug 9 2011, 01:40 PM
914 Wiring Harnesses Group: Members Posts: 8,527 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
The basic principle to recognize is that the FI components together, per model year, make a balanced system, primarily for a certain engine size.
The 1973 ECU was used for both the 1.7L and 2.0L, but the MPSs, dizzys, CHT sensor, injectors, TPS and entire air intake system are different. If you have a 1.7L engine and air intake system, the ECU will work, but you will need the correct 1.7L MPS, injectors and dizzy at the least... The 1.7L and 2.0L TPS are also different...they rotate different directions...so you will also need a 1.7L TPS. |
turnaround89 |
Aug 9 2011, 03:14 PM
i have a 1.7 mps that i can use, the injectors are 1.7 and the dizzy is also for a 1.7L...i will have to check the tps, all i can remember is it has 5 terminals, not 4. i think its part number ends with 021, but not 100% on that
Bleyseng |
Aug 9 2011, 04:09 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Run the 037 ECU with a 049 MPS and a 012 CHT with the yellow 1.7L injectors..the dizzy really doesn't matter...BTDT!
turnaround89 |
Aug 9 2011, 06:20 PM
i will give that a shot, thanks. once the thermoswitch shows up ill be able to get everything on the motor and back into the car
Lo-Fi Version | Time is now: 3rd June 2024 - 03:30 AM |
