Proper Gasket Material for Transmission Plate |
Scott S |
Aug 22 2011, 11:26 AM
Small Member Group: Members Posts: 1,697 Joined: 30-April 03 From: Colorado Member No.: 633 |
Hi All -
I was just notified by Pelican that the gasket I need for the rear plate on my tail shift transmission needs to be ordered from Porsche Germany and will take three weeks. The last time this happened with a PP order, I called three weeks later and was informed that the part was NLA (that is another issue all to it's own). So, I thought I would try and make my own. I have done this before, using cork, and it began to seep a bit over time. Do any of you have any reccomendations on the best material and thickness? It is sealing transmission fluid if that matters. Thanks!! (IMG:style_emoticons/default/beer.gif) Scott S |
Bartlett 914 |
Aug 22 2011, 12:45 PM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Hi All - I was just notified by Pelican that the gasket I need for the rear plate on my tail shift transmission needs to be ordered from Porsche Germany and will take three weeks. The last time this happened with a PP order, I called three weeks later and was informed that the part was NLA (that is another issue all to it's own). So, I thought I would try and make my own. I have done this before, using cork, and it began to seep a bit over time. Do any of you have any reccomendations on the best material and thickness? It is sealing transmission fluid if that matters. Thanks!! (IMG:style_emoticons/default/beer.gif) Scott S I used glossy plotter paper. I scanned the original and then printed this on the plotter paper I used a punch for the holes and cut the rest out with scissors. It doesn't not leak. |
Jeffs9146 |
Aug 22 2011, 01:00 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
PM Dr Evil! I think he has a bunch of these just sitting around!! (IMG:style_emoticons/default/beerchug.gif)
brant |
Aug 22 2011, 01:01 PM
914 Wizard Group: Members Posts: 11,633 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
don't make your own
I've made my own before and regret it I can get you my spare one if you need it. brant |
Scott S |
Aug 22 2011, 02:36 PM
Thanks all -
Contacted the good Doctor and I am all set! (THANKS DOC!!) |
Dr Evil |
Aug 22 2011, 07:11 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Should go out tomorrow (IMG:style_emoticons/default/smile.gif)
SirAndy |
Aug 22 2011, 08:27 PM
Resident German Group: Admin Posts: 41,672 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Jeffs9146 |
Aug 22 2011, 10:32 PM
Lo-Fi Version | Time is now: 4th June 2024 - 03:43 PM |
