Another deck height question |
tornik550 |
Aug 28 2011, 08:18 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I just finished checking my deck height. I used a flat piece of steel with a dial indicator mounted. I have the number I am looking for however I would like to double check using a second method. I was planning on torquing down the cylinders then checking with a flat plate and feeler gauges.
The trouble that I am having is- how do you safely and accurately torque the cylinder jugs to the case? I have seen people use several sockets or nuts. There is only a small edge for the sockets to sit on and the head studs start to bow out when I torque them. In the past, I cracked a fin doing this. What do people do to safely and accurately attach the heads to the case when checking deck height? |
76-914 |
Aug 28 2011, 09:13 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I just pulled them down snuggly then measured. After cross checking measurements for accuracy, I did the rest w/ a feeler gage and it was just as accurate!
tornik550 |
Aug 28 2011, 09:21 PM
I just pulled them down snuggly then measured. After cross checking measurements for accuracy, I did the rest w/ a feeler gage and it was just as accurate! Ok- does everyone agree that putting the bolts on snuggly are all that are needed. I hope so cause that would make life much easier. |
wertygrog |
Aug 28 2011, 10:34 PM
wertygrog Group: Members Posts: 428 Joined: 12-November 05 From: Long Beach, CA Member No.: 5,114 Region Association: Southern California |
Yep just snug all 4 headstuds down as much as you can before you risk cracking a fin!
McMark |
Aug 28 2011, 10:37 PM
I've done back to back tests and haven't found a significant difference between perfect torque deck height and just snug.
Here's my setup... (IMG:http://www.914world.com/bbs2/uploads_offsite/originalcustoms.com-419-1314592757.1.jpg) |
pcar916 |
Aug 29 2011, 02:52 AM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
Snug will do it.
tornik550 |
Aug 29 2011, 08:12 AM
Thank you to everyone for the advise!!!!
Lo-Fi Version | Time is now: 4th June 2024 - 07:12 AM |
