Six carb linkage setups |
hars914 |
Jul 16 2004, 05:39 AM
Member Group: Members Posts: 114 Joined: 6-January 03 Member No.: 94 |
Has anyone come up with a simplified and cheaper way of operating the carb linkage.
I cannot see paying all that money for the trans bracket setup. Plus it seems like there are to many adjustments that way. Any help would be appreciated. |
lapuwali |
Jul 16 2004, 08:09 AM
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
Modify the throttle arm on the crossbar so the pull is forward rather than aft, then just use a 914 throttle cable. I've never seen this done, but it wouldn't be all that hard to do.
john rogers |
Jul 16 2004, 12:07 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
On my six conversion we use the four cylinder cable and made a small "L" shaped bracket that bolted to the rear of the block, where the tranny is mated. A hole was drilled for the outer cable to go through and line it up with the throttle arm. The cable pulls the throttle arm to the rear. Good luck
Downunderman |
Jul 16 2004, 02:26 PM
Senior Member Group: Members Posts: 852 Joined: 31-May 03 From: Sydney, Australia Member No.: 766 Region Association: Australia and New Zealand |
I have a similar aggangement to John, but I had a custom cable made with teflon coated inner cable. I could never get all the bell cranks and levers to work out probably because the po modified it all.
john rogers |
Jul 16 2004, 05:19 PM
Here's a pict of mine. You can see the "L" bracket behind the fuel lines. The small cable is a bicycle inner and outer that goes to the heater lever and acts as a speed increaser when I start the engine of the race car.
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 16th June 2024 - 06:30 PM |
