Squeeling brakes, Really, really squeeling brakes! |
Elliot_Cannon |
Jul 18 2004, 12:03 AM
Senior Member Group: Retired Members Posts: 1,922 Joined: 26-March 03 From: Orange County Ca Member No.: 480 Region Association: None |
Has anybody had a problem with squeeling brakes? Really really squeeling brakes?
I also have a broken speedometer cable. Can you just put a new cable in the old housing? Or do you need to replace the whole housing? Cheers, Elliot |
94teener |
Jul 18 2004, 06:49 AM
Member Group: Members Posts: 209 Joined: 6-February 04 From: Jacksonville, FL Member No.: 1,636 |
Really, really squeeling brakes are sometimes caused by an improper rebuild, where the caliper pistons are rotated so that the high ridge on the top of the pistons is on the leading edge of rotor rotation, rather than the trailing edge. This will also cause the pads to wear very unevenly.
You gotta change out the speedo cable with a complete new one. Good luck with it, Phil |
tommy914 |
Jul 18 2004, 07:35 PM
Life is a journey, enjoy every turn. Group: Members Posts: 1,103 Joined: 15-September 03 From: Ridgeland, MS Member No.: 1,165 Region Association: None |
I once switched to a set of "carbon metallic" pads that squeeled like a feight train. Switched back to regular "metal master" pads and the squeel went away.
Anyone want to by a set of pads?? |
Lo-Fi Version | Time is now: 6th June 2024 - 12:12 PM |
