Elliot_Cannon
Jul 18 2004, 12:03 AM
Has anybody had a problem with squeeling brakes? Really really squeeling brakes?
I also have a broken speedometer cable. Can you just put a new cable in the old housing? Or do you need to replace the whole housing?
Cheers, Elliot
94teener
Jul 18 2004, 06:49 AM
Really, really squeeling brakes are sometimes caused by an improper rebuild, where the caliper pistons are rotated so that the high ridge on the top of the pistons is on the leading edge of rotor rotation, rather than the trailing edge. This will also cause the pads to wear very unevenly.
You gotta change out the speedo cable with a complete new one.
Good luck with it,
Phil
tommy914
Jul 18 2004, 07:35 PM
I once switched to a set of "carbon metallic" pads that squeeled like a feight train. Switched back to regular "metal master" pads and the squeel went away.
Anyone want to by a set of pads??
